72 suburban with a duramax (the build)
5 Attachment(s)
Here is some pics of this thing in progress.
Dates aren't shown on pictures, but are as follows: 12-29-2010, 1-6-2011, 1-8-2011, 1-8-2011, 1-9-2011 Attachment 767453 Attachment 767454 Attachment 767455 Attachment 767456 Attachment 767457 |
Re: 72 suburban with a duramax (the build)
4 Attachment(s)
More pics. Dates as follows:
1-9-2011, 1-10-2011, 1-10-2011, 1-31-2011 Attachment 767459 Attachment 767460 Attachment 767461 Attachment 767462 |
2 Attachment(s)
Dates:
2-1-2011, 2-1-2011 Attachment 767463 Attachment 767464 More pictures to follow. Need to sort through the memory card on camera. |
5 Attachment(s)
Here are pictures and dates when I could actually drive it around the shop on it's own power.
2-16-2011, 2-16-2011, 2-20-2011, 2-20-2011, 2-20-2011 Attachment 767468 Attachment 767469 Attachment 767470 Attachment 767471 Attachment 767472 |
4 Attachment(s)
Rest of these all taken on 2-20-2011
Attachment 767473 Attachment 767474 Attachment 767475 Attachment 767476 |
3 Attachment(s)
Very nice! Did you use a stock harness from a truck or a standalone ecu?
Wow, that is awesome :metal: It looks like a nice tight squeeze in there, but it looks good :chevy: It must drive and sound awesome !
It was nice seeing your Suburban in person! You did a great job on the install and in record time for a build for sure. And, thanks again for the sweet deal on the clutch TH400. It'll be put to good use. :lol:
firewall mods?
no firewall mods but the challenge was the trans tunnel because of the size of the allison started with a 4x4 tunnel then raised it about 4 more inches
I saw some pictures of the white short bed pick-up at SEMA with a D-max and that tranny tunnel was tall too!
well the trans is on the bench gettin the rebuild it didnt need but tryin to make it bullet proof I quess.
Is that your trans cooler behind your transmission? That's slick!
Gonna need to see some video....Please?????
thats the trans cooler it is a tube and fin derale 16 pass and is the only trans cooler I have on the trans. With that being said it is coming off and i am going to a plate and fin type cooler from the same company because of heating issues. They asured me that it would do the job i quess i should have done my homework first before purchasing the one i did.
If you are having heat issues I would definitely do something different! If the other cooler doesn't work, what about a hydraulic oil cooler? They will be more pricey, but with limited forced air-flow the "bigger-is-better" approach may be the way to go. A hydraulic oil cooler will also be tougher built. Maybe a spoiler between the frame and the rocker to force some air over the frame if that is the way your fan pulls. Are you using a trans temp gauge? Now I really wish I was going to the diesel drags!
Edit: Sorry, I forgot to add this link. Have you seen the PPE truck? |
Nice project!!!
the trans temp runs about 150-170 on my 2010 truck and I have seen trans temp as high as 220 in the burb in know these are not good numbers for any oil. Temp breaks down oil the fastest. Derale told me I just used the wrong cooler for the job so I am going with the pro opinion on this on I quess. Also thought about the shroud to pull fresh air in but not good for the gravel road I live on when it rain and turns to mud. I talked to them about the air shroud and they said it would not be needed. I will let you know the results.
Since I"m bugging you about coolers, what can you tell me about that radiator/fan combo? How does that hold up to the heat?
The radiator is a griffen 31 inch wide with 2 13 inch fans offset. I have never seen the engine temp above 195 unless you are running the air and sitting in traffic then it will just keep creeping up the highest recorded temp i think is 230. If i am stuck jn traffic I wiil just turn off the air and roll down the windows. On the power tour we saw some pretty high outside temps along the way so all in all I am happy with the engine cooling.
Very cool burb!
I saw it at the Des Moines Goodguys event. |
when will our projects ever be complete?
here is the latest update from the car craft nationals in minneapolis check it out. look at you tube 72 suburban duramax burn out. As i have said before I am not handy at the computer so dont know how to upload the link
