Project: 72C10 "Clear Blue Sky"
4 Attachment(s)
I have been doing my project for about 4 1/2 years now and never started a build thread. Slick67 inspired me to start one, so here goes. I had a 72C10 in high school, and have always liked these trucks. I am planning on doing a frame off restoration, and use it for truck meets and shows. I will try to keep these pictures in order the best I can. I want to do a 4/6 ECE drop,
350/TH350 combo, power brakes, pwr steering, 17" or 18" wheels, but want to keep that classic truck look also. I also plan on going with BC/CC paint, that I will do myself. I found a SWB for $1500, but the guy took $1200. It has a step-side bed on it, (it was originally was a fleet side and he traded the bed). I will go back with a fleet side bed. It has allot of rust, and holes where metal used to be..LOL So I guess the tear down will start. I know everyone like pics, so I will try to get as many as I can. Attachment 770245 Attachment 770246 Attachment 770247 Attachment 770248 |
Re: Project: 72C10 "Clear Blue Sky"
Got a little done tonight after work, starting to remove the front clip and engine this weekend, it's a start. More to follow...
Attachment 771190 |
Engine coming out , that only leave 10,203 more things that have to come off, be painted and get put back on..:lol:
2 Attachment(s)
Engine out, an clip off, I want to fill all the extra holes in the frame and make it smooth. I plan to have everything all powder coated gloss black. I am sure no one will notice all the extra holes filled and smoothed, but it will look awesome...
Attachment 771719 Attachment 771720 |
2 Attachment(s)
All the extra holes on the frame are getting weled up, so they frame will be smooth and clean looking for powdercoat.
Attachment 773022 Attachment 773023 |
A few updates, the frame is all smoothed off now and getting ready to be sent off for powder coating. I aslo cut some holes for the exhaust to be routed through. Moving right along, I have all new front end parts, ECE 2" Fr drop springs and spindles, 6" Rr drop springs, rotors, wheel bearings, etc.
I still have to paint all the ties rods, couplers, end links and such...tks for looking. Attachment 778111 |
2 Attachment(s)
Finally got some suspension parts painted and the frame is going back together. All bolts were replace using grade 8 hardware, about to have a roller again...then onto sheetmetal replacement..here are some pics..
Attachment 779732 Attachment 779733 |
3 Attachment(s)
3 Attachment(s)
project looks good, any mods to the frame to happen ?
No real mods to the frame, I just welded up all the extra unused holes, and made it all smooth. Also made some cut outs for the exhasut to be routed through the crossmember. It has a ECE 4/6 drop kit, shock relocators, adjustable track bar and I added power steering. |
Looking good
Posted via Mobile Device |
Keep up the good work looks great so far!
5 Attachment(s)
Cab update and progress, this cab is rough, but I have time and want to learn sheetmetal repair and painting. This will take some time, but I really wanted to keep the original cab. I will order all new sheetmetal and such, now I just need to get after it..ha
Attachment 782116 Attachment 782117 Attachment 782118 Attachment 782119 Attachment 782120 |
4 Attachment(s)
2 Attachment(s)
small hole above gas filler fixed now,,,few more tacs, and some smoothing out.
Attachment 782861 |
looking good!
Nice work man. :cool:
3 Attachment(s)
top of dashboard replacement, taking out all the rusty metal and replacing the top of the dash.....I also eliminated the defroster vents for something a little different.
Attachment 784347 Attachment 784348 Attachment 784349 |
5 Attachment(s)
Pics replacing R & L inner and outer rockers, cab corners, partial floor pans, lower A pillar, all was blasted and sprayed with epoxy, this was way more work than I planned for,,,:lol:
Attachment 784472 Attachment 784473 Attachment 784474 Attachment 784475 Attachment 784476 |
5 Attachment(s)
