6 Lug Rear Discs With 15" Wheels
4 Attachment(s)
This set of brackets will allow you to have rear disc brakes on your 6 x 5.5 bolt pattern ’64-’87 GM truck 10 and 12 bolt rear differentials, and be able to run 15" wheels. This rear disc conversion is completely bolt on with one exception. The drum/wheel register will need machined down to approximately 3.06”. I do recommend upgrading to ½” wheel studs at this time, but it isn’t absolutely necessary for the installation. The rotors used with these brackets as well as the calipers are easily found at your local auto parts supplier. The basic application for the rotors is '88-'98 K1500 Silverado or Suburban front rotors. The calipers used on this conversion are referred to as the D369 calipers. These are also found on the '88-'98 K1500's as well as the C1500's. A complete parts list with part numbers is included with the brackets.
The cost on this set of brackets with installation hardware is $179.50. Satin black powder coating is an additional $28.00. Shipping within the USA is a flat $16.25. See our website for current pricing. If you are outside of the USA, contact me for a shipping cost. For payments I accept PayPal and money orders. Credit card payments can be made thru PayPal. To place an order, post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time. |
Re: 6 Lug Rear Discs With 15" Wheels
Hmm, with these calipers there won't be a parking brake, will there?
Posted via Mobile Device |
That is correct, no parking brake.
Ttt
You never cease to amaze me, Captain. Great work!
I'm not ready for this set, but when the time comes, you can bet I'll let you know. |
Thank you for the compliment :)
Do you still make theses brackets? If so has the price changed?
Thanks Posted via Mobile Device |
Yes I still make these, and no the price has not changed. I also replied to your PM.
Ttt
This is awesome, I've been torn whether I should just change my front brakes to 5 lug in case I wanted to go to rear discs later on, but now I don't have to worry about it :-D I love the stuff you fab, Captain
Is there any calipers that have the E-brake that would work for this application?
I want to keep my 6 lug front and rear. but I want to disc brake my front and rear any suggestions? |
I don't currently have a 6 lug rear disc bracket that has an e-brake that will work with 15" wheels. However I do have these if you could run 16" or larger wheels.
http://www.67-72chevytrucks.com/vboa...d.php?t=445599 Quote:
That's fine i'm running 20" wheels, just looking for help on cheaper disc brakes all the way around. it dosen't help being new to the fourm. so kinda playing the dumb card.. and doing a lot of reading.
But I noticed your the man with the info and parts or brackets.. Thanks for the help. |
Bump.....
Ttt :)
Any plans to come up with a 6 lug rear disc brake setup with an e-brake? I would really love to make the change but I have a t56 and need the ebrake... thank you
As I stated in my thread for the discontinued 6 lug rear discs, I am currently working on another bracket set that will have an e-brake and will work with 15" wheels. There just is not a lot of time with working 70-80 hrs a week. I am currently waiting on some laser cutting for verify the final design.
Got it., I did not see the thread you are referring to. I understanding work constraints. I will hold out for the 15 compatible rear discs though... Theres a lot of hills in my area.
I'm at a point where I'm ready to undertake this as well Capt. However, I want to be able to run my slotted mags if possible. Patiently awaiting your new design.
I haven't forgot about this. I've just been burried with work, including one big job I am trying to get done. I have the latest laser cutting sitting in the shop, just lacking time to get to it. I should be able later this coming week.
No problem at all. We all understand outside pressures with life.
Does the new design used the D52 calipers?
No it will not be using the D52 caliper. The new design will use the smaller Metric caliper commonly used on the '79-'85 Eldorado, Toronado, and Riveria as well as the '82-'91(?) F-bodies.
I am very interested in a set of these brackets. I am ready to buy with cash in hand when the time has come. Hoping to have my truck ready before LSFest. Hope everything goes well with the laser cutter.
James |
3 Attachment(s)
I did pickup the laser cutting on Friday, and finally got time to check the fitment today. Everything looks good with the caliper I was using, which was a standard front caliper. I ran out of time to check the fitment with an actual e-brake caliper, I will do that tomorrow. I don't forsee any problems, so I should be able to ship 3 sets of these right away. I will start a for sale thread tomorrow sometime. In the meantime here are some pics.
