Engine bay cleanup - Throttle/kickdown bracket Q's?
I just dropped in a new 1406 Performer and was curious what kind of brackets you guys are using for your throttle cable/ return spring/ kickdown brackets?
Looking for a neat clean looking install... I posted a question about this a little while back in the engine section but didn't get any responses so I figured maybe I would get a little more by posting here |
Re: Engine bay cleanup - Throttle/kickdown bracket Q's?
2 Attachment(s)
I used a stock bracket mounted to the rear manifold bolts.
http://67-72chevytrucks.com/vboard/s...ight=edelbrock
The throttle and TV cable bracket is BTO due to my 700r4 |
Made mine out of aluminum that bolts to the rear studs of the carb will take some pics this weekend and post them up.
2 Attachment(s)
you will love the 1406, just installed mine too with a alum intake...used some parts from the q-jet throttle and a LITTLE FAB..... same kick down set up... works great.. i will post a better pic tomorrow
http://i963.photobucket.com/albums/a...torintake2.jpg |
