Serpentine belt conversions
5 Attachment(s)
This a used serpentine belt conversion is for small block chevys. The pics are my demo set up. The kit includes RH AC bracket, AC R-4 pump R134 or R12, LH Alt-power steering bracket, 100A Alt, power steering pump, belt tensioner, fan clutch, fan blade, clutch mounting studs & nuts, water pump pulley, crankshaft pulley w/bolts, braces and nuts & bolts. The RH bracket originally used 2 mounting bolts to the cylinder head. If your cylinder head only has the traditional one hole it will still work fine. I have sold many of these that only used one mounting hole with no problems. These will come cleaned and ready for detailing. I can detail a kit for 100.00 extra which will include media blasting and painting in satin black. I have four of these conversions for 225.00 plus shipping. Big block conversions also available.
Re: Serpentine belt conversions
would you consider selling this setup minus the power steering pump, pulley fan,clutch, and crank pulley?
Put me down for one.
How do you want to be paid? |
Will this fit 1970 4X4 radiator shroud, and the upper radiator hose. Do you have any with out A/C. What would shipping be to 30263. Any pics installed in trucks?
will this work with the regular water pump ordo i need a reverse flow?
How much for a BB? Do you have any pics?
Thanks |
so your selling basically jus the brackets and pullyes for 225 or does it come with the ac compressor, alternator, and power steering pump??
You will need a new water pump, belt, and pig tail for alt. |
I am interested, but do not have the budget right now. Please let me know if you have more available in the future. Thanks!
Do you still have some available? This would pretty much bolt up to a 70 gmc with a 350 right?
Subscribing to this in case you have more in the future
I would also be interested, Can you run the kit without the fan? Or does the fan hold the pulley on? I have electric fan so would not need fan and clutch if it will work like that. Oh and 134 would be my choice. Thanks Tim
Sold two still have two left. TTT
so how would I tell if this would fit on my 350?
Will this fit a 1976 SB 400 factory motor(no mods) with out A.C.?
