Parting out 72 Suburban K10 350 TH350
Parting out 72 Suburban 4x4. THIS TREAD IS FOR THE SUBURBAN 0NLY PARTS. All the common Sub-PU parts are in a thread of there own in the PU board. http://67-72chevytrucks.com/vboard/s...d.php?t=521770 All prices are plus shipping.
Olive green deluxe rear door panels. Nice condition 75.00 pair SOLD Fuel tank filler neck. 27.50 SOLD Fuel tank vent tube. 27.50 Rear barn doors upper slides/locks. 35.00 pair Fuel tank sending unit. Just replaced with new repop. 30.00 SOLD Tail light lens. Very nice DQ. 12.50 each SOLD LH barn door lower latch. 12.50 RH barn door upper, lower and center latches. 32.50 Tail light housings 7.50 each RH rear window regulater. 20.00 LH rear window regulater. 20.00 Exhaust hangers front and rear. 22.50 SOLD Lock set and switch with matching key. 35.00 SOLD |
Re: Parting out 72 Suburban K10 350 TH350
5 Attachment(s)
pics
5 Attachment(s)
Fuel tank. A few minor dings, very solid, nice inside. 75.00 SOLD
Fuel tanks straps. 25.00 SOLD Rear AC complete with wiring, cover, and hoses. 175.00 Upper molding kit with barn doors. With all the clips. Very nice condition. No dings. 125.00 SOLD I have a second set for a lift gate. |
how are the headliner panels?
Interested in the spare tire clamp if its original. And also looking for a driverside front blinker assembly, dont need the lens. And if possible would need the other plug for blinker assembly. The one that goes into rad. support.
And the outside front bumber brackets if you have any. Thanks Shawn. |
Price on the plastic plugs shipped to Iowa 50171. Thanks. LockDoc |
Thanks, Tom |
Tom,
Do you have anymore of the upper molding clips? If you'll part those out, how much would you need out of them? Posted via Mobile Device |
LockDoc |
Will take matching lock and key set...can you put with other items and ship all at once?!
Adam |
Tom,, willtake the "Fuel tank filler neck. 27.50", (Thats the one with the
overflow tube ?). If you haven't sent the headliner bows,and spare tire clamp, maybe stuff it all in one package,,, Thanks,,,Pat |
Thanks, Tom |
Do you have a suburban splash shield? The one the goes behind the driver side rear wheel?
If so condition and price. |
[QUOTE=tll74;5346458Pat, no I haven't shipped yet. I'll look into putting it with the other stuff and report back.
Thanks, Tom[/QUOTE] Thanks,,PM me the $$$, Pat |
Tom
If you come across a rust free lower DS quarter from rear of driver door to front of wheel arch I would be interested in it. need from the bottom up to the crease just above the lower wide mouldings. Thanks Richard |
Money sent for locks...
Tom, Yes, I will take the plugs from all of the SUBURBANS. LockDoc |
Still interested in the plastic interior plugs from this thread and the Parchment seat belts from your other Suburban parts thread. LockDoc |
Tom, Your latest PM didn't make it through. I double checked and the last PM I received from you was 5-4-2012. I guess you will have to try it again. Thanks. Leon |
need front and rear bumper brackets for a 4x4
If you have any plastic plugs left after you take care of tll74 I am interested in a complete set both the small and larger ones.
Thanks Scott |
Are the front and rear door panels still available?
Do you still have the upper molding trim?
Is there a safe and reasonable (price) way to send to 34953? |
