Bagged Beater, Daily Driver (76 Blazer)
4 Attachment(s)
So I've have this thing since 2004 and drove it with a static slam (Axle flip, spindles, cut coils) for about three years before I had a shop weld in a bigger notch and install a 4 link and bags. After seeing how simple the air plumbing was, I regretted paying someone to do it. I was less than impressed with where the valves and lines were routed, so I ripped everything out and redid it all myself.
My main thorn in my side has been these two POS Viair 12volt compressors. They take forever to fill my two 3 gal tanks and they're loud. I upgraded to a slightly larger Viair and was very unimpressed with it's recovery time. (Upwards of 10 min) JUNK! I decided to stop fooling with junk, bite the bullet and cough up the dough for the most badass compressor I've seen yet. Just over $1000 gets you this belt driven heavy truck style compressor that's turned by an 80 amp 12 volt motor. It makes less noise than a 12v electric Viair and it fills my two 3 gal tanks from 0-150 psi in just over 2 min. So when I'm cruising and playing with the air ride, the recovery time back to 150 psi after the pressure switch kicks in is only about 30 sec. I've been driving this to work every day for the last 6 weeks or so with no complaints. I LOVE IT! I added a deep cycle RV battery with an isolator to power the pump so I can run it at shows without killing my main battery or starting the engine. |
Re: Bagged Beater, Daily Driver (76 Blazer)
My old compressors..
Badass Blazer!!! hope to check it out in person one day!!
4 Attachment(s)
Some :canada: style mounts
3 Attachment(s)
Few more pics, last one is when I bought it.
Nothing is more Canadian than hockey pucks as isolators, I have a few trucks with those body mounts!..... I am a little worried about how bad you say the pumps were, I have similar pumps. My neighbour told me to get rid of them in favour of a larger engine driven style pump like yours, because they work so much faster. I don't want to tell the guy he was right....... Starting to sound like it's going that way.
I always had two pumps wired together. I made sure they were getting enough amperage, I chased all my leaks and was still never satisfied with their performance. They wouldn't be bad for a set of helper bags for a work truck, but not great for a full air ride vehicle that you want to play with need to have air on demand. I've talked to some guys who don't drive their vehicles much and don't care if their compressor is slow, but mine is a daily driver and I like to ride low and be able to jump up in a second for a speed bump, driveway or dip in the road. This compressor has made my air ride vehicle way more fun to drive.
The Viair 380 isnt the choice 12v compressor. I had 2 Viair 450c's and was very happy with them on a single 5 gallon tank. You probably would have been better off just mounting a York 210 engine mount compressor and saved yourself from having a bulky box in your luggage area. Also would have been easily half the cost. You have a very nice blazer by the way!
I thought of that, but this way I can run the compressor without running the engine, plus it was extremely easy to install.
your blazer is my favorite on here....hope mine ends up that nice...and yeah, about the compressors. i have 1 380 on my tan truck and it takes like 10 mins to air from 0-140 with a 5 gallon tank. i think one of my problems is the compressor is like 10 ft away from the tank. my 380 is mounted where your 380's were and the tank is where the extra tank would have been under the cab. funny, i thought i was being unique when i picked that spot for the 380...lol
love the hockey puck isolators! . |
Thanks for the compliments. Maybe I should have tried a larger diameter air line to the tanks, may have helped a little bit.
3 Attachment(s)
Well my 20" tires were gettin to be unsafe, so I'm going to throw some new tires on the smoothies in a few days. Until then, I'm rollin on some 15" steelie dubs..:metal:
Posted via Mobile Device |
Hey mr pops, I've got some 20/22's with brand new rubber for sale, matte finish c5 coys.
Check my build thread!! I'll take the smoothies on trade! Lol Posted via Mobile Device |
Looks rad with those steelies too!!!
to me that would finish your blazer and i couldnt imagine a better look to keep it old school . |
I've considered painting my smoothies. I wish the price would come down for 20" rally wheels, those are sweet too.
2 Attachment(s)
I swung by a local tire shop and saw they had a decent selection of used rubber out back so I picked out a pair of 255/45/20's for the front (same as before) and decided to go a little fatter and taller on the back (wanted more of a hot rod look) with a pair of 265/50's giving me about 1/2" of clearance to my inner fender. The tires have at least 60% tread left and the guy only charged me $150 for all 4 tires mounted and balanced!
