Bench seat console
2 Attachment(s)
Decided that I wanted a cupholder console that looked authentic on a bench seat. Shape a base out of wood to the contours of the seat. Sanded and shaped the back and front pieces to the same angle and curves as the original console. Glued and stapled scraps from the original seat covers to the wood frame to give it an "original" look. Cleaned up and reinforced a couple small cracks in the lid, and painted the top section and lid satin black. Console emblem and trim ring were in real good condition. Small piece of doormat carpet trimmed to fit over a 1/4 inch piece of plywood as the "bottom" of the console. Nothing is holding the console in place on the seat other than friction. May attach a small strap to the bottom and pull it between the seats and attach under the seat.
Regret not taking more pictures during construction. Wasn't all that hard. Patience to get the contour right and fitting the console lid bracket. |
Re: Bench seat console
Meant to include this one of the bottom....
Very nice!
I like it a lot. I would think about making a strap to hold it in place, maybe something that goes around the bench and secured with velcro? The way I drive, and the stiffness of a 4x4 that console for sure would bounce off the seat. |
Looks great! I also agree with you guys about securing it. Don't want to ding up the console or dash... LockDoc |
That's great. It's what I would have wanted.
Posted via Mobile Device |
Two things.
Maybe a strap that could utilize seatbelt to secure it. Second- anyway to get a pic of the design on your seats? Is it factory? Looks sweet! Posted via Mobile Device |
Clipped in place with simple strap and disconnect buckle underneath the seat. Seat cover pattern is standard 69-70 scroll style deluxe interior. Purchased this one from board member Tim Christian a couple years ago, including instructions, hog rings and pliers.
Looks great. Ive been holding on to a counsel like that to do the same thing.
Thanks! |
I don't know whether or not it's the same seat...but I measured the bottom of the top section of the original console and it's 19". If you look at the picture showing the side, it looks like the base of the original console is a bit longer than the seat and it tapers back... maybe even a full inch if you consider the back is also at an angle. I'm guessing they are very similar in length at it could work. The front of the curved bottom base that I made is right up to the edge of the piping.
The width of the console is about 11.25" Hope this helps. |
Yes it does, thanks very much for the info. I figure since I will need to make a new base contoured to the seat back and bottom anyway, I can always adjust the overall length to fit just right. Now I just need to find a good console to modify.
Thanks again for the help. |
PortHeadlight,
Thanks for posting these project photos, I'm planning on unashamedly copying your idea exactly (except in blue vinyl) in my '72 Suburban. How did you end up securing it to the seat? I was thinking of using the middle seat belt, but maybe a completely independent strap is the best way to go. Bill |
I used an independent strap. 1" wide strap with clip. I secured the strap on the wood base. The strap goes over the front of the seat and between the seat and backrest. Clips underneath the seat.
Thanks for the info. I'm still looking for a good candidate for this project. They sure do want quite a bit for the originals in good condition, and even in not good condition.
2 Attachment(s)
Very cool. I modified a console in my K5 Blazer to hold a stereo so that I would not disturb my original dash. I cut to fit a cheap styrofoam cooler as well. Now I've upgraded my front seats.
Awesome! I really like when folks that make "period correct" if not NOS perfectchanges that keep the integrity of the original truck... but that's just one man's opinion. My radio is new version that looks original but I can plug in music or use bluetooth.
NOS guys are awesome too! |
3 Attachment(s)
I made a pattern out of cardboard and made this console for my Suburban with cup holders, junk tray, stereo, and speakers. The main reason was that I didn't want to cut my dash for a better stereo.
Nice job, looks factory:metal:
