Calling everybody that has switched out a gas tank on a 73-87
I know im probably gonna be told just to get under their and take it off but it never hurts to ask some questions
whats are the steps to take them off my gas tank is been leaking and just got my new one in the mail want to do it saturday, i dont have any help its a 74 shortbed 16g gallon tank i know the sender is their and the wires and rubber lines whats the best way to lower it can i lower the tank all the way to the floor with the sender still in it or would i have to lower the tank a bit then take the sender off then lower it? |
Re: Calling everybody that has switched out a gas tank on a 73-87
i would take the bed off first then go from there. it's alot easier to see what your doing with the bed. you can take the bed off and replace the sending unit with in a coupla hrs. but if this is your first time i would take the bed off. then you can disconnect the sending unit and wires and drop the tank.
i dont have a cherry picker or any type of forklift or hoist to help
i get what yor saying do, i wanted to get it all done in a day |
i took the frame bracket's off put it all together put all the fuel line on first and put it in ?good luck
Sometime the lines on the left tank are long enough to allow the tank to drop down enough to make it easier to work with. If they have never been replaced they will hard as a rock and need to be replaced anyway so just cut them, unhook the ground from the frame and then unhook the sending unit wires. Replace the lines with some a little longer and be careful not to kink them when reinstalling. Also make sure it's as close to empty as possible.
Be sure to remove the two brackets that bolt to the frame with the tank, then you can remove the straps and swap tanks. |
It's my left drivers side tank by bracket yall me tank straps
This will be my first tank swap installing a new tank Sender pretty easy to take off? Posted via Mobile Device |
Put a floor jack under the tank. Unbolt the brackets, then lower a little. Reach in and disconnect the wires and hoses. Then lower the tank all the way down. Sending unit is easy to replace once you can get to it. Basic hand tools, floorjack, and some patience is all you need.
Yeah, with the bed off your not laying under the truck, but the tank is much lighter than a bed. |
That's a ***** of a job, grab 2 jacks, empty the tank, take off the skid plate, unbolt the gas tank and slowly lower with the jacks until you can take off the gas lines, replace sending unit etc...replace in reverse order, I've done this 3 times, not fun, but patience is key.
DON'T PUT GAS IN IT! Make sure it is as empty as you can. Nothing worse than wrestling one of those things slushing around.
I have changed out a tank on my 84 with the bed in place. You will have to lower it slightly and disconnect any wires and hoses from the top. Cutting the wires is not a bad thing, so keep that thought in mind. Wires are easy to fix and you do not have to kill yourself lowering the tank. Change out the fuel tank sender after it is on the floor.
ughhhh. If you can take off the bed. I wish I had.
If you take off the bed you risk messing up the holes in the bed or the bolts/nuts if they are rusted.
The way I did it (twice). Get a couple of concrete blocks and short lengths of 4x4s and 2x4s until you have them stacked snug against the tank. Remove the bolts holding on the strap. Remove a couple of 2x4s from the rear of the tank. Now you can get up there and unfasten the hoses and the electrical connection on the sending unit. There is a ground strap on the frame with a big lock washer type eyelet that needs to be removed also. Remove 2 x4s from the front, then the back, one at a time, until you have the tank resting on the concrete blocks. Slide the blocks out from under the tank and remove the tank from under the truck. Use a flashlight and remove the hoses. Replace the hoses with new ones. It is a good idea to clean off the grounding eyelet, bolt, and frame surface where it mounts. If you have a Spectra brand sending unit it will likely cause your gas gauge needle to bounce some when the truck is in motion (some say this is not true.) Replacing the sending unit is easy. Just tap that tab sticking up (counter clockwise, I think) with a flat screwdriver and hammer until it backs off the tank - be gentle - you don't want to snap that tab off. I think the sending unit will have installation instructions. I bought genuine OEM Delco o rings because they were rounded like a a traditional o ring and seemed to fit the groove better than the one size fits all type o ring supplied with the Spectra sender. 2 BIG CAUTIONS: 1) WEAR SAFETY GOGGLES, NOT SAFETY GLASSES. THE DIRT AND CRUD IN AND AROUND THE TANK WILL FIND ITS WAY INTO YOUR EYES FROM THE OPEN SIDES OF YOUR GLASSES. AT LEAST WEAR SAFETY GLASSES WITH SIDE SHIELDS. 2) YOU WILL GET VERY DIRTY - WEAR COVERALLS OR DISPOSABLE CLOTHING, OR CLOTHES YOU WILL EXPECT TO GIVE A HEAVY DUTY WASH AFTER THIS PROJECT. This project is not especially difficult, just time consuming and dirty. If you take your time it will be easy - don't expect to rush through it - allow a full day. I always make arrangements for alternate transportation when I work on my truck just in case something goes wrong and the truck is inoperable. I forget the exact sizes of the replacement hoses - a cheap digital caliper from Harbor Freight is always handy to have around to measure the nipples on the sending unit to get the correct size. The LMC catalog has a good picture of the tank, straps, and hoses, wires. I am attaching a pic of my 83 C20 dual tanks. |
Thanks everybody for the help, i will try to take pictures as i go about this
piecesparts Thanks for that tips about the wires, was looking between my frame and he gas tank and saw where the ground wire goes to the sender but theirs one of those yellow caps(for like household wiring? lol) thats probably a good time to fix the ground wire tucsonjwt You think the local auto parts store should have it wha type of hose should i be looking for? another question could i still use my sender hasnt given me any problem or nothing |
i was googling for like a hour and never found this
maybe the way i worded it that will help me out to along with all yalls great advice |
As long as your bed bolts aren't junk they should come loose easy enough. At a minimum I would take the bolts out and secure the bed a foot or so high, at least the front. Watch cab and bumper clearance on the paint, duct tape over masking tape can help significantly. The clearance of the lifted bed is well wortht he minimal anout of time to create it. I have done many tanks/sending units in a lot of different set ups and in a lot of different ways over the years and when I can gain extra clearance I take the time to do it, it generally saves me time in the long run but it definitely save me aggreviation.
As with anything I try to think of projects I want to do in the same area so I maximize my efforts, for instance if I wanted to clean and coat the bottom of the bed it would be a great time to tackle both, pull the bed for access to the tank and flip it over and do the bottom of the bed while it's off. Maybe, frame work, shocks, wiring, brake lines, just what ever is int he area. |
It was quite easy for me to siphon as much gas as possible from each tank, support the tanks with wood blocks, and unbolt the brackets from the framerails (the strap bolts are too easy to break). Spray the bolts thoroughly with penetrating oil, or similar, prior to starting. I removed the attachment screws for the filler necks from the outside of the truck, and by removing wood blocks one at a time, I lowered each tank enough to disconnect the sender and hoses. Then I lowered each tank to the ground and slid them out from under the truck. You can remove, and install, the senders by tapping them in a rotating manner with the edge of a flat-blade screwdriver (it'll be obvious once you see them up close). I then washed each tank thoroughly with the garden hose, and allowed them to dry completely. Installation was easy with the help of my rolling floor jack, and I just reversed the process.
Here's the two 20 gallon tanks ready for re-installation: Attachment 994053 Good luck, Frog! Todd. |
One last thing: If you have the plastic tank shields that are under the tanks. It is good to keep them, they do protect the tank from road rash. HOWEVER cut some large holes in the bottom, so that they drain water out of them, the rust issue goes away if there is no wet dirt built up against the tank iteself.
I used a large hole saw to make my holes in mine---many years ago, no issues since. |
Good point on not using a metal screwdriver. A piece of hardwood like oak or maple will work.
If your sending unit is working just reinstall it. You might need to replace the o ring - just a few dollars at any parts store. Be extra careful taking that sending unit out of the tank and re installing it. It has fragile parts on it and a nylon sock on the end. If the sock is shot you can get a replacement. I forgot about unscrewing the fuel inlet hoses prior to tank removal. I have a dump conversion so my fuel inlet hoses are just sitting there not hooked to the bedside. When you take the short hoses off between the sending unit and the hard lines you can take those hoses to the parts store when you pick up a new o ring and just have the store clerk measure them up. Depending on your truck, I think you have 3/8", 5/16", and 1/4" hoses etc. As I said, the best bet is to measure the outside diameter of the sending unit nipples, but you can just match them up at the parts store - they do this all day at the store. The only issue is if the hoses are ballooned out of shape you have to guess at the true diameter. If your new o ring does not fit well, just clean up the old one and re install it. The aftermarket o rings seem to be extra fat and don't fit well in the factory recess. |
I just did my 83 and for me I lifted the bed with a block of wood and a floor jack. I also had to drop the tank. You can do it with just dropping the tank, but I had a very hard time getting the fuel lines back onto the tank pickup with the bed in place. At least on mine, you cannot get the tank pickup out without dropping the tank. The cab corner is in the way. It wasn't difficult, just kind of a pain. Make sure you tank the tank group out before you drop it. I had to solder mine back on because I broke the ground wire off before I realized it wasn't unbolted.
My tank came with a oring
im gonna have to use scissor jacks my floor jack went out' my truck didnt come with the shields |
Granted your sending unit may still be good and you don't want to spend the extra money...BUT...once you figure out how much of an @$$ pain it is if you ever have to replace it, you'll probably want to do it now.
I'm a stickler for watching my pennies and not spending them when I don't have to, but it's just one of those things where you bite the bullet now and not have to worry later down the road. As for taking it off, everyone's just about got it covered. Just have to get in there and do it. Take your time and don't get frustrated. It's been a while since I did it and the only mistake I made was either putting it back up backwards or putting the wrong strap on the front. We didn't realize it until we had it hooked back up and trying to strap it in place. That's when it was time for a break, a cold one, and a new plan. The 2nd time around though it was much easier :D |
