Buddy Bucket Console/Center Seat Dimensions
Can any of you buddy bucket owners out there take some measurements for me?
I wanted to see if I could get the dimensions of the "box" (length, width, height) including the dimension from the bottom to the centerline of the hinge. Also, the thickness of the material it is made of. Also the dimensions of the seat and backrest. Same thing; length, width, and height. Thanks in advance for any help! |
Re: Buddy Bucket Console/Center Seat Dimensions
Can somebody help this fellow out??
I'll try to get some measurements and pics tomorrow if no one else beats me to it. Nate
Thanks guys, I appreciate it!
5 Attachment(s)
Let me know if this helps, I don't know how to make the dimensions on the photos. 16 gauge .0625 thickness All measurements are from inside of bends. Inside dimension is 12 5/8" wide and 16 5/8" long. The sides and front are 3 5/8" deep and the rear is 7 3/4" deep. The return lip on the sides and front are 7/16" The front corner angles are 15/16" x 15/16" x 3 5/8" high. The rear Z support is 9/16" x 7/8" x 15/16" x 7 3/4" high.
5 Attachment(s)
Hinge width measurements. 1 7/8"--1 3/16"--5 1/4"--1 3/16"--1 7/8"
3 Attachment(s)
The outside diameter of the hinge is 3/8" The center hinge bracket bolted to the seat measures 5 1/4" wide by 4 3/16" from center of hinge with a 1 1/2" return that has the screws.
Hope this helps and not confuses you :lol: If you need additional measurements let me know. Maybe if you can make the photos with a line I can give specific measurements. Nate
That's AWESOME Nate, thanks a ton! Could I ask another favor, and get you to measure the seat and back pads? Then I should have everything I need.
Thanks again! Posted via Mobile Device |
Did you ever get the remaining dimensions you needed?
14 5/8" wide.
17 3/4" long.
The top cushion appears to be 14 5/8" square
Thank you
Getting ready to take a Slosh Tub buddy bucket console to the upholstery shop. Any chance anyone can post the thickness of the seat bun and armrest portions as my upholster will do the foam as well. Thanks, Chris
