Educate me: Steering stabilizers on 4wd, all years?
2 Attachment(s)
What year 4x4s had steering stabilizers? '72 only? Pics (Thanks Tom Korinek) show what I believe is an OEM stabilizer bracket ('72 Blazer) on the tie rod: the stabilizer attaches to a plate affixed onto the Dana 44 as shown. Was the stabilizer offered for all years?
Re: Educate me: Steering stabilizers on 4wd, all years?
'72 was the first year,as far as I know.
Interesting...learn new things here all the time. I guess that bracket is one year only deal then. The '72 model had several one-offs: doors, door panels, window regulators, tow hooks, aux tank, SS tailgate handle cover, rear view mirror...
1972 3/4 ton 4X4 - another hard part to locate is the rear brake cable (one year only) for a eaton Ho52. I been holding onto a NOS one for a while, cannot find a match or suitable replacement anywhere.
Since the front is a dana thing, and if 72 was the first year, wouldn't it be the same from 72 up to late 70s-early 80s?
From what i recall 72 was the first year and in 73 the tie rod did'nt have the bolt on bracket but a hole made in the tie rod
So are these after market? Seem old.. Mounted on a 70chassis. The one on the tie rod seems the same..http://i1150.photobucket.com/albums/...8aa4738eec.jpghttp://i1150.photobucket.com/albums/...038045197e.jpg
Posted via Mobile Device Posted via Mobile Device |
The tie rod bracket looks like a GM piece.
^^ Yup. And the axle bracket is aftermarket.
Interesting!
Probably the tie rod bracket was taken from a '72 at some point
Digging up an old thread here...
I have a 72 without any steering stabilizer, or the hardware for it. Where some made without, or was it just taken off at some point? I'd like to add a stabilizer, without the hardware on the truck, what are my options? The ones I looked at don't come with the mounting hardware. |
My 69 has one. looks og...always thought it was factory. d44 closed knuckle.
still learning. i guess ill remove it! :) |
To verify the year of the axle, you can check the date on the ring gear. If its original ring and pinion, it will be real close to the installation date of the OE D44. |
Cheers! Nim |
So is that just a shock? I ordered from rancho what I thought was the right charged cylinder but it arrived with threaded rods on both ends.
I thought that 69's were open knuckle ?
okay... I went out to the farm and took pics over the weekend.
Cant upload photos, at least not the same way I used to and I'm not computer literate so I'm gonna just throw my hands up. Kind of a bummer tho because pics say it all. Here's what I learned about my truck. The axle is factory. I assumed the stabilizer was because it all has the same rust (LOL). It is bolted on tho and the plate that has the stabilizer bolted to it also has the driver side shock bolted to it so it serves dual purpose as stabilizer and shock mount and bolts to the axle outboard of the spring perch. I find it kind of interesting that it shares a bracket with the shock but it is a beefy stamped u-bolted item. I guess I wont remove it after all. Looks like it was meant to be there. c Beers! Nim |
I Have A 1971 Chevy Dana 44 3/4 ton Front Axle With The Factory Mount On The Axle Tube.
