78GMC Project for Life
I'm pretty new here, but i've been doing my homework over the last year and decided on this 78 gmc shortwide as a project. Now from the crazy rides you all have done, which all are in a league of the own i decided on a Mcgaughys 4.5/6 for mine, which consisted of 2 1/2 spindles and 2inch springs and flip kit and cnotch out back with belltech drop shocks all around. Now i have the front finished and have moved to the rear. My only issue back here so far is that PO removed some leafs or maybe not. I dont know. I have 2 long leafs and then a short one on the bottom. I ve been looking like crazy. I understand that there was a 52 inch and a 56 but my question is how many leafs should i use on mine? Any help would be appreciated and pictures will be coming shortly. Thanks for any help.
Re: 78GMC Project for Life
Welcome to the boards! I'm in okc not too far from you. My truck had 6 leafs and the overload after flip, Im running '67-'72 trailing arm now.
My 84 has 3 and the overload which resulted in about a 5" drop..If you have only 2 you won't get a 6" drop out of your flip kit.
Since your in the city. If you need a set of leaf springs I will give you mine just pm me and come get them ASAP
Posted via Mobile Device Posted via Mobile Device |
Hell yeah. Thanks for the responses.
So if I'm understanding right here I need more leafs For more drop. Man that sounds stupid when I say it. That makes sense. So I ll probably go with 3 and the Overload. What size are those leafs that you don't need? I ll take em. I'm gonna measure mine and see and let u know. And how many leafs are there. Thanks again guys. Posted via Mobile Device |
Hey rich can u elaborate a little. Am I looking for more leafs for more drop. Is that how it's working?
No you don't need more springs unless you dont like the ride.
Do the flip you will be happy.. Posted via Mobile Device |
Ok this is what ive got. I found that mine are 56 inches and 2 1/2 wide. thats 26 center to front eye and 30 center to rear eye. With the responses and research it looks like mine is 56 which are only sold now with like 8 plus leafs. Thats fine but with what ive heard most are running like 4 or 3/1, which is 3 on top one on bottom. Well the 56 does not have that low of an option in leafs so now my brain is exploding.
Aren't those shackles riveted in place?
Does anybody think the leafs that I have would be ok. Or should I replace.
When I first did the flip it kinda freaked me out how low it was..So give it a chance. Now I look at it and think "maybe a little lower".
