Problem with PW and PL's on passenger door.
On my 03 2500HD I can not roll my window up or down nor can I lock or unlock the door by power. It does not matter whether from the drivers or passengers control. Even by remote it will not lock. This is on the passenger door and all the rest work just fine. I did put in a new window motor and regulator two years ago and have worked fine up to now. All of a sudden it just stopped. Any suggestions?
Re: Problem with PW and PL's on passenger door.
Any help would be apreciated. I am getting ready to put this truck up for sale locally and need to get it fixed.
Check in the door jam where the wires go though i bet you have a broke wire there
I am going to take the door panel off tomorrow. I guess there was a TSB out on these trucks about this issue. I have read that it might be the PDM (passenger door module) which from what I take is the switch assembly itself.
Keep us updated on what it was.
Posted via Mobile Device |
I haven't had time to take the door panel off yet. I will let you know what I find out.
