T1I08TLM - Can you decode this!?
Ok, game time people. Who can decode this block I.D.
T1I08TLM GO! |
Re: T1I08TLM - Can you decode this!?
T I believe is tonawanda n.y. which is the plant it is built as for the rest I have no clue
Posted via Mobile Device |
Good start!
1969 Corvette 427 390 Mt HP that's what I found on the suffix code
I'm thinking assembly date of January 8, of 1969 not 100% on that though
Where did you find the code for this answer!?
I looked up the suffix code (lm) and the rest I just know took awhile to come back to me
Here's a list of suffix codes http://www.nastyz28.com/gm-chevy-cod...-suffix-14.php
So the suffix code isn't "tlm". Just lm?
That I'm not sure about didn't even see the t there
Here's the right one sorry bout that TLM 1972 Truck 402 210 400 L-47 AR, 10, 20
http://www.nastyz28.com/gm-chevy-cod...-suffix-15.php
Arrg. I see that now. You had me excited for a second. This is my engine in my 71. I was told it was a 454. Decided to check it out myself. Guess its a bit smaller than I thought.
Still a Chevy! Posted via Mobile Device |
Tonawanda, November 08th, 72 Truck L47 402/210 C10-20 w/AR BBC or maybe a 76-77 Truck LM4 400/175 SBC.
Without a casting number and date code this is kind of moot and a waste of time. |
Ya it is still a really good engine though. I haven't messed with the BBC that much but I believe you can stroke the 402 using a 454 crank Nanking a 440 c.I.
Well someone's a negative nancy. :)
How about I grab the serial number for ya. Posted via Mobile Device |
Ss Tim not arguing with you but why would it be november
Serial: 8999280
I lied!
3999290... Posted via Mobile Device |
The I is incorrect, this is easy to tell cause there are no letters that would be in that spot, only numbers. So either it's a miss stamp or a miss read. Either way the most likely is a 1 misread as a I. So the code becomes T1108TLM T= Towanda 11= November 08= 8th day of Nov. TLM= 3 different motors depending on the year. With casting number 3999290 it narrows down to one motor, 72 Truck L47 402/210 C10-20 w/AR BBC (just like Tim said) Also it should have a automatic transmission. (M49) It would be nice to see the date code, as a double check on the year. (I also have a 71, 402 listed) |
Just did some more research, 3999290 could be 68-72 402/396, so we need the date code to see if you have the 71, 402 310hp or the 72 402 210hp.
The 71 motor could have a auto or manual trans. The 72 motor was a auto. I'm betting on the 71 as the 72 was a prob. a car motor, although some references list it as a truck motor. Check the date code for a definitive answer. I'm betting the date code starts with a K and ends with a 1. Should be 2 numbers in-between. |
Bruceman1968 thanks I figured it was miss read just guessed the month though thank you
Could swear that's an I.
http://i.imgur.com/6YTFOcX.jpg Posted via Mobile Device Posted via Mobile Device |
Where is the date code?
Its possible it might be a mis print usually one or two letters then four numbers then two or three letters
