Swaybar question.
I just received a swaybar that I purchased on-line from a salvage yard. Its for my 69 C10 SWB chassis. When I first contacted the yard it was because they had one available for a 1 ton truck. I believe it was a 1 1/4". I bought it. The guy from the yard calls me later that afternoon and tells me there is a problem with the swaybar. I asked if he priced it wrong? He said "No, my guy cut it getting it off." I was like.....what!? Anyway, he had one from a half ton so I bought it instead and it arrived today. Now my question is this. Should I use the swaybar from the half ton or wait and find a heavier one? Is there that much NOTICABLE difference in the handling between the two?
Thanks! |
Re: Swaybar question.
To what degree you could tell the difference depends on many variables. That said, some swaybar is waaaaaay better than no swaybar.
Thanks for the reply! I have completely rebuilt the frontend with poly bushings and a MgGuaghy's drop/disc kit, so everything is new with the exception of the a-arms. The only thing I didn't have was the swaybar. I measured the one I got today and its a 1 1/16th, the one I wanted was 1 1/4 inch. I hate that moron cut it, I mean its not like the sawsall slipped and cut it in half! I just thought the larger diameter bar might make it handle better. I'm not building a pro-touring slot racer, just a solid BBC/TH400 combo for fun on the weekend. A guy here told me to go with the 1 1/16th one because the other one from the 3/4 or 1 ton would be too stiff and would have a negative effect on the ride quality. He said it would be too harsh to enjoy.
I have a 1 1/4" bar from a C20 on my 77 Cheyenne thats bagged. It made a very big improvement in the handling and body roll. It did NOT make my ride stiff or harsh in any way. The 1 1/16" should work just fine, but the bigger bar would be better. |
Thanks guys!
I'm going ahead with the one I have but I'll keep my eyes open for a 1 1/4" bar. The yard told me they would refund the cost of the swaybar if I decided I didn't want it, but it would be cheaper just to keep and use it than to pay shipping to return it. When I do find a 1 1/4" I'll swap them out and who knows, there may be a board member who would be interested in the 1 1/16" bar. Thanks again!! One more thing. Should I use the ECE mounts or just bolt the bushings straight to the frame? I've seen several done both ways. I have a 4.5" drop with roughly 28" front tire. |
My drops are typically 5-6 in the front so I just bolt the bushings directly to the frame (spindles + spring or bag drop). I planned to do the same w/my dually but I dropped it a little differently (spindles + notched x-member) & the bar seemed to be in bind (under compression sitting in the shop) so I utilized the frame stands. |
No I haven't bought them yet. Will the swaybar be just as effective if I bolt it straight to the frame?
I have never seen where going up in sway bar size had any problems handling or ride.I think he was thinking about springs if you run a real stiff springs it will ride rougher.
On good pavement, no, you will never notice a ride stiffness change. It can be over-done on either end, balance is the key. |
