Engine pictures
I would like to see some engine shots, for some ideas on running wiring. I'm replacing the engine wire harness in my late 70's 305 V8, and would like to see creative ways to run things.
Re: Engine pictures
Its nothing fancy, but this is my 79 305 V8.. These were taken shortly after buying this truck. The pink tie wraps are long gone. I cleaned up some of the stray unprotected wires too.
http://i166.photobucket.com/albums/u...Picture333.jpg http://i166.photobucket.com/albums/u...Picture335.jpg |
Re: Engine pictures
This is probably the finest example out there...bar none...! You see any wires..?
http://i21.photobucket.com/albums/b2...9ss/sub/21.jpg |
1965 C10 Chevy 283 c.i. Powerglide Transmission.
Re: Engine pictures
Hey Rich.. I dont see any wires on my engine either. I ran a differt gas pedal and used the hole for my harness. I do have an aftermarket harness mind you. I ran the wires to the headlight from under the inner fender and the plug wires are around the back of the engine and under the headers. For small block you can use Corvette wires. The only wires you will see are the ones gong to my turn signal lights in the hood.
Re: 1965 C10 Chevy 283 c.i. Powerglide Transmission.
any more pics of this engine bay? Looks very clean! |
Re: Engine pictures
'60 305 V-6, mated to a 4 speed Hydra-Matic. Upgraded to dual brakes, 500 CFM holley 2 bbl carb., rear gears dropped to 3.23 and every friggin' option I could find!
Re: Engine pictures
Re: Engine pictures
This is a more updated picture. I have fired the engine but only on Starter fluid.
Re: Engine pictures
Heres mine
Re: Engine pictures
327 dual quads......
Re: Engine pictures
I was at Papa's show and walked by your truck, I only counted one carb what happen to the other one. |
Re: Engine pictures
Posted via Mobile Device |
Re: Engine pictures
Re: Engine pictures
Thanks for the pictures, lots of inspiration for how mine might look someday. Plenty of great ideas turned into great engines and I'm sure others, like myself, that like to see what's out there appreciate it. Can't get enough.... keep them coming.
Re: Engine pictures
BBC in our 66 burb...
Re: Engine pictures
Here's my 402 big block in my 66 short stepside
Re: Engine pictures
Going a different route... actually this is a picture from about 5 years ago. Been a little slow going, just got the body work done and the truck painted last month.
http://laanderud.com/65chevy/022707/.../DSC044241.jpg |
Re: Engine pictures
5 Attachment(s)
some very good lookin engine bays in this thread :metal::metal::metal::metal::metal:.. the engine bay is my favorite part of a vehicle
here is mine 454 only thing thats missing in a few of the pics is just the belts and a vacuum line but it wont have ac or power steering.. im gonna make an electric heater so i could get rid of the heater lines headlight and fan wires ran under the fender spark plug wires under the headers engine wiring comes out behind the passenger side head and a little bit lower |
Re: Engine pictures
1966 c-20 292 stock motor, driven daily.[IMG]http://i792.photobucket.com/albums/y...psfc67c048.jpg[/IMG]
Re: Engine pictures
3 Attachment(s)
1964 GMC. 401 Buick Nailhead punched out .030
Attachment 1119621 Attachment 1119615 Attachment 1119616 Heres my build thread showing the install... http://67-72chevytrucks.com/vboard/s...=1#post5212525 |
Re: Engine pictures
Wow, so many cool compartments and engines! Love the alternates like the Buick and the Hemi, but I'm also impressed with the eye candy big blocks. I'm also a fan of the inlines. So much to choose from. It's a good thing I can only afford what I already have or I'd go broke trying to figure out where to go next. Those Cal Custom styled BBC valve covers look especially cool.
Re: Engine pictures
1966 305 V6 solid lifter.
