bucket seats
Just bought a 87 short bed. Would like to replace the old bench with buckets. What have some of you used? THANKS!
Billy: chevy: |
Re: bucket seats
Welcome to the forum! :metal:
Click on the link below it has some suggestions of where you can look and has some pictures of people who have done bucket seats in there trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=562485 |
Re: bucket seats
I have several sets of factory pickup bucket seats but they all need recovered so finding a nice set is prety tuff. However, I like to use 88-91 Suburban buckets since they are much easier to find and usually in good shape. Both Blazers and 'Burbs have tracks which curve down slightly at the rear of the tracks instead of upwards like the pickups. To solve this, I like to use 2 sets of pickup benchseat tracks and adapt them over to the 'Burban buckets-the other reason for this is now I can have an adjustable bucket with armrests! Check out this pic from my build thread...
http://i975.photobucket.com/albums/a...ps1d9e3ccf.jpg I haven't got around yet to installing the new LMC instrument cluster brushed silver trim just yet-but the seats look right at home. You don't always need a reclining bucket seat since room is tight but, I'm 6 foot and 190 lbs. so I can still set my seat how I want it and be comfy. The main thing at the time was I had a 1990 Suburban I was building and I bought another dark blue Burban for parts-well, after that truck was done, I aquired this shortbox and figured if only I could find another set of blue Burban buckets....then low and behold one of the local salvage yards got a 1990 GMC Burban in with seats that were super clean-just needed powerscrubbed and they are like new now....pretty crazy good luck I would say-I prolly have 3 complete dark blue interior kits worth of parts except for seats...lol! |
Re: bucket seats
Re: bucket seats
I did drill holes to locate the mounting points....then, I welded nuts from underneath the floor-it appears as factory tho-then, I undercoated them.
Posted via Mobile Device |
Re: bucket seats
2 Attachment(s)
These are the seats im gonna use on my stepside. anyone do this conversion before? {newer GM} anyone know what year they are?/ i bought them through CL out of the vehicle. i believe there out of a truck that was totaled. they will fit. cant afford to take no for an answer.gotta fabricate a base.
Re: bucket seats
5 Attachment(s)
my 78 Jimmy buckets are in rough shape
so i grabbed the ones from my 89 burb the base is 16 wide just drilled new holes jimmy bases are for a flat floor tho I put the dial on the outside as the jimmy drivers seat dosn't go forward, but the dial helps lean it when outside |
Re: bucket seats
Re: bucket seats
Re: bucket seats
Thanx {rs74?}I seen a couple trucks in the pix section with m so i know its do-able just lookin for some insight before i get goin on it-jeff
Re: bucket seats
gmachinz, post a pic when you get the rest of the interior done.
Re: bucket seats
Check out some of the seats these guys offer exspensive but cool.http://www.trucknvans.com/
Re: bucket seats
I'll definitely post some pics.....one of my weekend projects is to get my jute padding down on the floor, then install the new carpet. After that may come a custom stereo install....idk.
Re: bucket seats
Any idea how to remove the arms from the 1991 suburban style bucket seats?
Padding has completely disintegrated and want to repay. |
Re: bucket seats
Re: bucket seats
I tore down the bench and welded the ends together. It has worked out and are just as comfortable as the bench; still need to do the interior but Im driving around and no-one knows the difference
https://www.67-72chevytrucks.com/vbo...d.php?t=812100 |
