Radiator/Mater Cylinder Trouble .. :-\
Okay... man this custom restoring is becoming one heck of head ache. lol I knew it was coming but I didn't realize this much detail was coming into play. =lessons of wisdom.
Enough said: I ordered a Champion Radiator and after receiving it, it doesn't match up near to what I expected? Is there another company I order from that will literally bolt up with no fabrications? Or what year can I pull a radiator from to swap out? Master Cylinder/Booster= Summit Racing= Failure. :-\ I ordered the bracket to attach master/booster to fire wall.... Nope. No go. :-\ Another failure for the evening. Any idea where I can swap from another Chevy or buy from a company a booster/Master for a 1971 C10 Disc Brake chevy, 2wd, 350motor that will bolt up? Bolting up is the big deal. AS of right now, I might have to grind off the original bolts from the firewall and drill for new bolts holes to attached the cylinder with new bolts :=S "I just wanta cry" hahaha Online sites, wisdom, anything you have I'll take with an open ear! =In need. Thanks guys! |
Re: Radiator/Mater Cylinder Trouble .. :-\
have never had any problems with radiators that were readily available from the local auto parts stores// fit purrfect and were hiquality at lo prices// did have to wait about a day for them to get them into the store// did not have to pay shipping
as far as the brackets required for brake booster // i'd look in the parts section on the board for the brackets and i get booster and master cylinder again at my local auto parts store rteadily available most times they were on the shelf |
What are you trying to get to? Frank at pickem ups (here on board) has a upgraded booster m/c setup that will fit in stock location. As far as radiator, I used aluminum in one of mine and no major issues- modified lower pads but not a big deal. If wanting a stock type go to your local parts store- get a modine and take it home and drop it in. You do need to know what set up you have currently, if going from six or small 8 to 350 to larger upper rad support clamps/ retainers need to be changed usually . The four core rad is wider and used a different inner pad. If going custom there is no such thing as drop in stock location.
Awesome! Little Pricey for me, but he did give me great information though!! Thanks so much for the help!!!
