1981-1991 Chevy Blazer Full Size Complete Weatherstrip Seal Kit (18 Piece)
VISIT US HERE FOR GREAT PRICES 1981-1991 Chevy Blazer Full Size Complete Weatherstrip Seal Kit (18 Piece)
FREE SHIPPING IN THE LOWER 48 STATES http://1aauto-images.s3.amazonaws.co...00301/main.JPG This Full Size Chevy K5 Blazer & GMC Jimmy weather strip kit contains new, aftermarket replacement parts. The parts are built to strict quality control standards and will fit just like original parts. This 18 Piece weatherstrip kit includes the following pieces: (1) - Inner Header Seal for Removable Roof Seals front of roof to body (1) - Outer Header Seal for Removable Roof Seals front of roof to body (1) - LH - Bed Side Seal Seals Side of roof to quarter panel (1) - RH - Bed Side Seal Seals Side of roof to quarter panel (1) - Rear gate glass run channel Weatherstrip Seal Mounts in Roof and seals rear window when in up position (1) - Tailgate to Body Seal Attaches to the sides and bottom of the tailgate and seal the tailgate to the body when closed (1) - Inner Tailgate Window Sweep This is the long rubber squeegee that attaches to the inside of the tailgate and sweeps the glass as it goes up an down (1) - Outer Tailgate Window Sweep This is the long rubber squeegee that attaches to the outside of the tailgate and sweeps the glass as it goes up an down (1) - LH - Front Door Window Run Channel Seal Seals door glass to door when in up position (1) - RH - Front Door Window Run Channel Seal Seals door glass to door when in up position (1) - LH - Front Door to Body Seal Attaches to the pinchweld and seal the door as it closes (1) - RH - Front Door to Body Seal Attaches to the pinchweld and seal the door as it closes (1) - LH - Vent Glass Seal (one piece seal) Seals vent glass when closed (1) - RH - Vent Glass Seal (one piece seal) Seals vent glass when closed (1) - LH - Outer Door Window Sweep Sweeps door glass as it moves up and down (1) - RH - Outer Door Window Sweep Sweeps door glass as it moves up and down (1) - LH - Inner Door Window Sweep Sweeps door glass as it moves up and down (1) - RH - Inner Door Window Sweep Sweeps door glass as it moves up and down Fits Full Size SUVs with the removable roof If your weatherstripping is causing leaks allowing damaging rain in, then this weatherstrip kit is for you. Why not replace your old, hardened, rotted seal with this new, ready to install weatherstrip set. 10 Year Warranty This item is backed by a manufacturer's 10 Year Warranty. In the event this item should fail due to manufacturing defects during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty. |
Re: 1981-1991 Chevy Blazer Full Size Complete Weatherstrip Seal Kit (18 Piece)
ttt
