measurements for 8 foot wood bed floor
Does anyone have the correct measurements for making a replacement floor for 71 chev fleet side 8 foot box? Mine is completely gone and I have tried to measure several others and size vary as much as 1/2 inch for each boards. Info where I can find factory info would help. Thanks
Re: measurements for 8 foot wood bed floor
Welcome to the forum!
Try this: http://gmcpauls.com/47-72_BedWood_Info.htm If you don't want to make your own, there are several vendors. I used Mar-K and was very satisfied. Not cheap though. Google the forum ("wood bed" or some such search term) for a wealth of info ranging from cutting your own to finishing the wood. |
I used the specs on GMCPauls website and it came out spot on. That's what I would suggest. Its not difficult to do if you have access to the right equipment.
I found the info at Mar-k.com, look under installation tips.
