What tire sizes everyone running with 20's
Wondering what tire sizes anybody is running with 20's all the way around. I have 20x8.5 in front and 20x10 in the rear. Also what tire make have been looking at Toyo's. Just looking for some input if you have a pic that would be great too.
Re: What tire sizes everyone running with 20's
245/45/20 on 20x8.5 all around.
245 45 front and 295 40 looks good
The tires I'm using are in my sig. If you're not running bags or 5/7 drop, I doubt you'd want tires as short as mine. Check out summit racing, they have good deals and free shipping.
275/45 Falkens on 8.5 x 20 all around. 2 1/2" spindle 1" spring in front 6" rear flip.
Attachment 1233231 |
:chevy:245/40/20 front ...295/40/20 rear..Attachment 1233240
255/40/20 and 295/40/20.
I have 255/40/20 & 295/40/20, seems to be the popular size for 20's.
Was running 295/40/20 on the rear... switched to 295/45/20 for a little more sidewall. I ended up widening my wheel wells for a better fit. 18's on the front though.
We use Nitto NT420-S 255/40/20's and 285/40/20's on our customers trucks (fleetside with wide rear end and 5.50 BS 20X10 / 20X8.5 5.25 BS front) , make for some nice sizes. Nitto doesnt offer a 295/40/20 in the NT420-S or I would probsbly run them in the rear.
Thanks for the help guys. All the truck look awesome. Have to make a decision now
I can tell you from experience, 295/45/20 is a little tight with a 20x10 and 5.5" BS on the wide rear housing. I guess it depends on how low you run it. I was at 6" spring and 2" block and it rubbed a little when turning into a steep driveway or the local burger joint if the entrance was at an odd angle. (Hard to describe)
Not sure on your backspacing but .. I'd suggest 255/40/20 and 295/40/20 as others have. Toyos are good looking tires. My next ones will be Toyos. (Proxes STII) |
275/55r20 Hankook
http://i750.photobucket.com/albums/x...ps4cc7a37d.jpg |
Yep. What he said. My 295/40/20's rubbed and I was running a (60" wide) camaro rear end which is more narrow than stock. I just swapped in a narrowed 9" (58") and widened my wheel tubs 1.5" to run my 295/45/20's. BFG KDW's . Its an awesome looking tire. |
255/40 and 295/40. I think it's the best fitting/looking out there.
http://img.photobucket.com/albums/v2...n72g/ed5-1.jpg |
http://i132.photobucket.com/albums/q...psjxyfypgd.jpg http://i132.photobucket.com/albums/q...psc3t8bvid.jpg |
The 245/45/20 is a stock tire size for the Dodge Charger (at least in 2006 it was) so I went with it so I could rotate them. On the Charger they used 9 inch wheels. I don't think the tires look to narrow on the wheels but I would not go any narrower though. My 245/45 tire is 28.6 inches tall and 9.6 wide, and the 275/45 is 29.7 inches tall and 10.8 wide. 1 inch taller over all. When I need new tires I probably will go with a 275/40 tire which is 28.6 tall but is 10.8 inches wide. I hope this all helped your decision. |
255-40-20 all the way around
