What engine?
2 Attachment(s)
Its been many about 27 years since i ever looked at one of these which was in a 1945 Chev Pickup and it had a 216 i think, rebuilt a 235 once too, but..... fast forward to today..
I need to figure out what engine this is? don't remember where to look, its covered with grime, and the SPID only has 6 lines of info on it neither of which have engine type, no other stickers ect.. Its a 67 C10, far as i know the stock engine, guessing a Rochester 1 bbl? I need the standard plugs, points condenser, air filter ect, so i donno if I'm safe saying its a 250 or if i need to be more specific. . |
Re: What engine?
To my understanding there are only 2 L-6 engines stock in these trucks, 250 and 292. Based on the engine mounts that looks like a 250.
Re: What engine?
Thanks! its such a low option truck i cant imagin it having the larger but needed to ask.
This truck has 1 sun visor and 1 driver arm rest, none for passenger, weird.... |
Re: What engine?
Re: What engine?
It's definitely a 250 and not a 292.
Re: What engine?
There should be a stamping on the engine block behind the distributor that will give you the engine suffix just like the V8's
Re: What engine?
If you look in the bay look at the motor mounts. The 250 motor mounts would be across from each other. I believe the 292 are offset.
