1960-1962 4x4 tank?
Does anyone make repop underbed fuel tanks for 4x4's? The tank in my truck isn't original and I'd like to find the right one... Any leads would be appreciated!
Re: 1960-1962 4x4 tank?
No one repops the fuel tank for the '60-'66 Suburbans and Panels. Since yours is a 4x4, the frame width should be the same as a '63-'72. In which case you could use the '69-'72 Blazer tank with a 0-30 ohm sender. You just won't be able to carry a spare tire underneath.
I found a tank locally but I'm not sure if it's the right one. Does anyone have a 60-62 4x4 Panel/Suburban that still has the original tank? If so I could really use the measurements.
Heres the one from my 1961 4x4 panel. Same as my 60 and 61 4x4 Suburbans.
http://i270.photobucket.com/albums/j...44E7B27E2E.jpg http://i270.photobucket.com/albums/j...6E29D4A02B.jpg |
