question about swapping rear ends
I have 65 burb.. full air ride. I found a 70 rear axle. im running wires with adapters.. question is... I have a feeling the tire will hit the body line when aired out. Has anyone had any problems?
Re: question about swapping rear ends
'70 and earlier rear axles are the same width. '71 and later are 1.5" wider. If you clear with the stock '65 axle, the '70 should fit the same.
