Anyone here run drag week?
As the title says, anyone take the week-from-hell? Looking for advice from someone who's run it in past years.
My trucks not ready for it, so we're planning on taking our T/A out to run Street Eliminator. The car is being built for low 9's but we'll probably run without the bottle and try to keep consistent 10.10-10.30 |
Re: Anyone here run drag week?
A buddy and I fallow it online every year and have wanted to do Drag Week bad, but we never have anything to take. Sorry I'm no help, but could you post up a little info on your T/A?
Its an M6 01 Ws6, milled/heavily worked 5.3 castings (if you look at the TSP stage 2-3 heads, its setup based on that), longtubes, Fast92. Kasper spec'd cam which we get ground locally. Makes around 580hp on motor, and has a 2-stage 250 plate. Runs 10's straight, should be 9's if we can keep tires and a rear end under it when the plate hits.
Biggest problems with it currently are the neglect of the suspension and rear end up to this point. We managed the 10's through a 10bolt which hates the driver, and pretty much gave up the ghost at road-course day last season. The push for drag week will be mostly related to getting a Fab9 and new suspension out back, getting the front to unload itself, and getting a cage in it so we don't get tossed. |
Sounds like a cool car, I had a 97 T/A and went 6.79 in the 1/8th on a 383, th400 and 200 shot. Car still had a/c and the factory 10 bolt, but it wasn't 2 weeks later the poor rear said I give up and I had to trailer it home.
One of these days I'm going to find the 00-02 black on black auto ws6 car I've always wanted! |
Its a pretty fun little ride. It gets project-schizophrenia tho, as the "purpose" of it has changed a few times. Road car turned track car turned road going drag car turned....etc etc etc
Was the 383 done on an LT1 base, or an SBC? |
Drag week is on my bucket list.
I think the problem now is actually being able to get in. I think registration gets filled up within minutes of them opening it. |
It was still a LT1.
Lots of money and all the tools and extra parts you can think of or fit is a start.
I may have bit off more than I can chew but I would like to take a shot at 2015 drag week in a c10. Engine is sitting on the floor and cab goes on the jig table april 1. Its going to be tough. Worse case we take another car thats done already. I have a lot of baja racing and endurance racing experience so Im hoping that will help. I cant wait, its going to be great.
I'd prefer to take the truck as you gain the advantage of the bed space as well as trailer space. With the T/A, we don't have much internal room with the cage.
The only advantage it offers is the amount of stock stuff its retained, so emergency parts are reasonable to find anywhere. Towing a 12x9 trailer or whatever will be interesting. |
I ran DW in 2013- it was more fun that I had imagined. I did it in my 1965 C10 running the daily driver class. I had a relatively fresh engine that I had not tuned and was not spraying. I took a lot of tools and some parts but only had a couple of small problems. I tried to do it again last year but had metal in the oil at the last minute and had to drop out.
Be ready when registration opens up! I am still on the fence on trying it this year- I am waiting to see where it will be. |
Ive been brain farting on registration dates. Doesnt it usually open in early April and sell out 8min later?:lol:
Reg opens in April, usually gets filled within an hour (including waitlist). I'd expect 400+ entries this year.
I woke up to a text saying we have two more sponsors interested, so lets hope we can convince em to cough up cash. |
Im a little bummed. Reading the rules for 2015 and with the build we have planned it only fits the modified class where I will probably get out horsepowered. Oh well. It will be a great experience non the less.
I would LOVE to compete in Heavy Iron but I have a feeling that is gonna be THE class to watch this year from a sheer insanity standpoint. The T/A could probably run daily driver since we are taking all the Nitrous off, but I'm unclear about the "must register in lowest class your qualified" part of the rules. I assume we'll just do Street Eliminator because we're still stock frame-suspension style, and it should be able to do the ultra low 10's that Street Eliminator will require. |
I have a 468 sitting on the floor that made 752 on motor and good for 300+ worth of the squeeze. and I think I can get 800 out of it with a few changes on motor We are planning of cramming that and a T400 into a big back window short bed. shooting for under 3000lbs
A good friend builds drag cars for a living so he want to back half the truck with his kit. Running a 315 drag radial which I may have to change to meet class rules of no wider than 11.5 inches tread width. We have a few other cool things that we are trying to line up right now. Soon as my shop is empty the beginning of april the cab will go on the table and we will be hustlin to get it done. Should go out and run low 9s and be very streetable. Should being the key word. |
These days, low nines won't get you a top three in modified or pro street- both take high 7's to low 8's to be competitive. Street Machine eliminator (previously known as daily driver) with its 10.00 sec min. ought to be a lot of fun this year.
Not a comment on you personally, but if you (anyone really) are waiting till April to start a build, you are either very sadistic or just plain unrealistic. EVERYTHING takes longer than you want and don't forget testing and replacing the stuff that doesn't work for you. If you choose to do it, good luck! Oh- and don't forget that there is a 200-300 mile drive everyday so make sure your vehicle can make that. The drive kills as many cars in not more than the track does. Regardless what you run and in what class, the event is super fun and everyone is really nice. |
Get the DW talk back up and running. I picked the cab up yesterday. Im practically ready. :lol:
Sorta related to the topic, we're having 4" frontrunners made from Tq Thrust II's. We've run the full size rim since inception, since they don't sell a real frontrunner in that pattern. We'll probably be running a 17" frontrunner and a 15" rear, which I love but get hated on for.
Keep doing it! I love different and ill bet it catches on. Ive seen a few west cars do it too. Im torn on it.
Ya I actually picked up on the style from some drag-vette guys who were running the 17" up front with that 15" out back because of overall width/size limitations.
Finding drag tires in 15" alone is worth the cost of doing it. It really limits rear brake options tho. |
