Lowering my 1970 C20
I am new to the board and have really enjoyed looking at everyones builds and the wealth of information found here. I am just starting a build on this truck and one of the first things I would like to address is lowering & converting to 5x5 lug and front Disc. I am hoping to drop front 5 1/2 " and possibly 7" in Rear.
I have some questions maybe you all could help me with: Can I use a C10 Drop spindle kit on a C20? What would be best way to achieve this drop? Suggestions? Advice? Thank you in advance for any and all help. :) |
Re: Lowering my 1970 C20
welcome from TEXAS!!!!!
i can't help ya with your drop question but you might post it the suspension section for more help. and also wanted to say :wop: |
I agree on the pics, but unfortunately I live in Maine and we have had 127" of snow this year! Preparing for spring ;) Sorry didnt see suspension thread.
I went with a 6 inch rear drop and 4 inch front drop. Used two inch lowering blocks and four inch shorter springs on the rear along with a bent pan hard bard for clearance and a c notch. The front was 2.5 inch drop spindle and 1.5 inch shorter spring.
snow? what is that.... lol we had a pretty cold morning this morning, got down to blustery 34*, burrrrr
No 5 lug for me yet. I have 5/3 lowering so far. I used springs from GMC Paul's, relocated shocks and trac bar from CPP. Good luck!!!
Hey rodzilla67 ...
:welcome2: to the forums and :hi: from Ohio. I will move this to the "Suspension" forum where you might get addition help. |
As I commented in your other thread, ECE is the only company that will let you keep all the rest of your suspension stuff and run 5 lug brakes with their spindle.
Scroll down here and see the C20-C10 spindle. http://earlyclassic.com/catalog.aspx...ry=New%20Items And here is a good link that covers many of the questions you have. http://67-72chevytrucks.com/vboard/s...d.php?t=662011 |
Thank you for reposting this for me. |
Just wondering if I can use C10 spindles on a C20? Are they that different?
Was also looking at the possibility of: http://www.ebay.com/itm/391054955572...%3AMEBIDX%3AIT |
Idk about spindles though if c10=c20 Basic 12" 5x5 http://www.mcgaughys-suspension.com/...ys-part-63156/ 63-70 drop spindle used that year ball joints and tie rods. http://www.mcgaughys-suspension.com/...ys-part-63173/ 13" upgraded 5x5 kit drop spindle included http://www.mcgaughys-suspension.com/...ys-part-63151/ |
Tree-50, thank you so much for the links and tips. If I can figure out if I can use C-10 spindles on a C-20 I'll be ready to go! lol
Rodzilla67,
Lots of info on front changeout. What is your plan on converting the rear end to 5 bolt? |
3/4 ton lower a--arms have a larger balljoint hole. You will need 1/2 ton lower a-arms and you will have to switch to 1/2 ton balljoints and outer tie rods. Simpler choice is to use the "3/4 to 1/2 ton CONVERSION spindles" offered by ECE. |
Best option to convert an 8-lug truck to 5-lug |
Ty Lolife. Awesome info!
Just use google man not that hard
http://67-72chevytrucks.com/vboard/s...d.php?t=454824 Here's a couple good threads to look at. Member way2lo2 is a good source for lowering blocks and u-bolts. |
