2000 Silverado Part out 4.8l V8
5 Attachment(s)
Im parting out 2000 Chevy Silverado LS extended cab 2 wheel drive short bed.
4.8l v8 auto. Update New Pricing alternator $30 ac control panel $30 air bag $30 Bed liner Plastic Drop In $60 cluster $30 computer ECU $60 dash cover $20 dash bezel $20 Door glass Drivers $40 Door shell Passenger $40 engine 4.8l V8 $500 fan clutch $20 fender Driver $50 ignition switch and key $40 master cylinder $20 rim with tire (each) $60 starter $30 steering column $40 steering wheel $40 visors pair $20 intake manifold $80 throttle body $75 fuel rail $25 injectors $25 coils ignition $45 air box $30 chassis frame $100 fender well plastic $10 gas tank $30 gear shift $15 horn $10 parking brake pedal $20 power steering pump $20 power steering pully $10 rack and pinion $50 radio (cd player not working) $15 seat rear $40 sway bar $20 vacuum booster $20 wiper bottle $20 Wire Harness engine with trans wire $130 Wire Harness Headlamp-Front Lamps $20 Wire Harness dash $40 ~~~ITEMS ALREADY SOLD ~~~ ashtray SOLD alternator SOLD ac blower motor assembly (under dash) SOLD ac control panel SOLD ac compressor SOLD ac compressor SOLD bed SOLD Brake lines SOLD bumper front SOLD bumper rear (Has dent see pic) SOLD cab SOLD carpet (needs Cleaning) SOLD core support SOLD console SOLD Coil Springs SOLD door handles lock and key SOLD Door shell Drivers SOLD Drivers Door panel SOLD Door regulator Drivers SOLD Door regulator Passenger SOLD Door glass Passenger SOLD drive shaft two piece SOLD Passenger Door panel SOLD exhaust full length SOLD fan shroud SOLD fan clutch SOLD fuel pump SOLD fender Passenger SOLD fender well SOLD Glass Stationary Rear (you have a guy to pull it) SOLD Glass Windshield (you have a guy to pull it) SOLD Glass X Cab (you have a guy to pull it) SOLD headliner SOLD Grill SOLD Glove Box Door SOLD headlights SOLD Hood SOLD Jack Tools SOLD leaf springs SOLD mirror driver SOLD radiator SOLD rear end SOLD Receiver hitch SOLD rear brakes SOLD starter SOLD seats front SOLD shocks rear SOLD transmission 4l60 SOLD tailgate SOLD Tail lights pair SOLD window switches SOLD x cab door SOLD plastic steering column cover SOLD u bolts SOLD Wire Harness Passenger door SOLD wiper motor SOLD Wire Harness Headliner SOLD vortex engine cover SOLD Additional items still available from the 5.3 ac compressor $60 transmission 4l60 Slipps sometimes $150 headlights $20 fender well $20 fan clutch $20 Wire Harness engine with trans wire $145 Wire Harness Headlamp-Front Lamps $45 Wire Harness dash gas tank $45 horn $15 parking brake pedal $25 power steering pump $30 power steering pully $10 vacuum booster $25 wiper bottle $15 master cylinder $35 rim with tire (each) $60 computer ECU $75 |
Re: 2000 Silverado Part out 4.8l V8
5 Attachment(s)
more
5 Attachment(s)
additional photos
5 Attachment(s)
If i didn't like it, just ask
pm or text me for more specific photos |
Do you have any of the accy brackets for the front of the motor?
Dukkie this is John94chevy
I interested in engine wiring harness for 5.3l for swap i,m planning. |
sending pm.....now.
how about the maf sensor and the throttle cable bracket on top of intake???
cable bracket i can do 25 shipped to you |
Interested in the heads off the motor if willing to sell separate? If so, what is the casting number on heads?
Thanks Chris |
I'm not to far from ya and need a drive by cable throttle body
