Holley carb MSD distributor and aluminum pulleys
4 Attachment(s)
Some more stuff from around the shop.
Holley 0-81670 415 670 cfm street avenger. I bought this and ran it about a 100 miles chasing an engine issue that ended up being a bad muffler. Paid $399 from summit for the carb and another $50 for the TV cable brackets $350 for the carb, $30 for the brackets or $360 for it all. MSD pro billet distributor in good shape. Was saving for the 65 but now going LS. $225 SOLD Set of new billet pulleys and brackets for small block with a long water pump. All have been powder coated. Going LS so need a new home. $125 for the set. Sold Thanks Jimmy |
Re: Holley carb MSD distributor and aluminum pulleys
can i see a pic of the carb tv cable assy?
I'll take one tonight.
Jimmy |
dibbs on the distributor ;)
Jimmy you have a PM |
Marv the box went out today.
Jimmy |
any luck with the tv cable adaptor set up pics?
To be honest forgot to do it. will try and do it in the next day or so. Everything in the shop is stacked on the benches and anything else I had to get it up off the floor. The high tides with this last big storm were a pain.
Jimmy |
Jimmy do you still have the pulleys and brackets? Do you know if they will fit a 350? Is one of the brackets for a power steering pump/reservoir?
I still have the brackets. They will fit a 350 with a long water pump and the brackets shown are for the alternator.
Jimmy |
Would you take $100 for them?
How about $115 shipped.
Jimmy |
Sounds good...sending PM
This carb still needs a good home.
Jimmy |
