Rim Size and BackSpacing for 85 Blazer
I have an 85 Blazer awating 33x12.50R15 BF Goodrich All Terrains. I want to get the proper Rims. I am pretty sure that 15x10's will be fine.
You guys are the Pro's. What is the Back Spacing that I need to get? 3 5/8 or 4 1/4. Thanks, -IoWnZa |
Either should do. 3 5/8 will stick out a little further. Welcome to the board.
So you are saying that if I get 3 5/8's then my Tires are going to stick out from the Body a little bit? I like that... Thanks for your help, -IoWnZa |
My fronts are almost half way out with 31x10.5's I don't know what kind of backspacing I have or how wide my rims are though, I like how the fronts stick out some though, The backs are about flush I think.
stock wheels
Stock rally style wheels are 15x8, with 4 inch backspacing. I have a set on my suburban and pickup.
Bill |
IoWnZa, Destructo
wow 2 other guys from the [H] forums welcome guys |
I bought some nice $150/each Aluminum Spacers (The good ones)for my rear wheels so that all 4 wheels are flush, cause I dont like it that the rear wheels are not as wide as the front. Wider is better! -IoWnZa |
did you get the ones with studs on them or are you having longer studs put in?
I got the ones that you put on, and the put your wheel on after it, and they bolt direcly onto the wheel, they are really nice ones. I had to get the longer studs to put them on, so that they would be secure. The Blazer looks A LOT better once all the wheels are the same width like that.
-IoWnZa |
where did you end up getting the spacers from?
-IoWnZa |
