Antenna cable seal
I h ave a 71 C-10 with a stock radio and antenna. The hole in the cowl is larger than the diameter of the antenna cable. Without filling up the gap with silicone sealant or similar product, does anyone know of a source for the stock antenna cable seal?
If I have to I will "fabricate" a solution but would like to use something meant for the application. It rains rarely in SopCal but now that we have had rain and more is on the way, I want to keep the moisture outside and not running into the the cab and all over the glove box insert. Appreciate any/all help !!! |
Re: Antenna cable seal
The antenna cable firewall grommet is avalable at many vendors.
Might you be able to recommend one? I have looked around the Internet and haven't found one yet. Even called O'Reilly's and they have no clue.....
