Fitech swap on my 1972 K20
I have not done much to my K20 in a while, I had been researching fuel injection for a while and after my brother put a 6.0 LS in his 54 International, I knew it was time to bite the bullet and modernize my old carbureted small block.
Re: Fitech swap on my 1972 K20
I figured I would show some pics of the current set up before the swap
Currently I'm running a 750 double pump mechanical secoundary, dart aluminum heads , headers , flat top pistons , and a 274 comp cam
Some pics of the new system I went with the tumbled finish in stead of the black, it's rated for up to 600 hp
More pics
This is the most up to date status, I'm currently waiting on the fuel command center to arrive from summit;)
Subscribed! I have been thinking about how nice this would be myself.
Also going this route.
I'm in!
How's it going?
Sorry it's been a while fellas , I got a little busy with my school work, but here's some more pics :). O2 sensor plate Tiged
Inlet fuel filter
Fuel command center
Hopefully today after wireing we will fire the old girl up:)
I just got it going and took it for a ride , the thing runs like a raped ape:)
It's a self learning system, the more it runs the better it runs !:chevy:
Cool.
Is your gas tank in the cab? If so, where'd you run your vent line from the command center? |
Have you noticed any better mileage?
Hmmmmm...... :hmm::gi:
I just looked up that Fuel Command Center and that is a slick set-up. You leave your exsisting low PSI pump in place and feed the FCC from it. It's a sump with a high PSI EFI pump inside, and you feed the feul injection with that. Nice & easy !!!! Thanks, now I have to spend more money !!!! "LOL" Gary |
Well fellas I'm into this deep so I figured I would treat the old girl a new set of slanted top value covers:metal:
:chevy: , sorry about the dirty engine bay , Weeks been busy and neglected to give the old girl her weekly cleaning:)
:chevy:
Is your fitech setup still running good? Any adjustments that you have had to make?
Yes yes , the system is running swell, I am very pleased with the product, still to this day I have rarely seen any one not be happy with the system :metal::chevy:
