67 Chev 12 bolt differential
My 67 C10 currently has 3.73 rear gears, has a 250 inline 6 and 3 on the tree. Looking to change the rear gears to lower rpm at higher speed. I'm told if I go lower than 3.55 I have to change the carrier also. Anybody have any knowledge of this?
Thanks... |
Re: 67 Chev 12 bolt differential
I'm sure someone will correct me if I'm wrong ,but sounds correct. My '67 12 bolt has 3.08 gears. I can only go up to 3.42 ratio.
I believe there are 2/3/and 4 series carriers?! |
https://www.ringpinion.com/b2c/DiffD...&DriveType=RWD
This site should give you some answers.there are a ton of these rearends out there so don't give up hope. |
