Motor mount help for 77 crossmember in 66 c10 using 94 clamshell engine mounts
What modification am I to do, keeping same motor mounts that came with 77 crossmember and installed in 66 c10. Also using 94 clamshell engine mounts. Thanks in advance.
Re: Motor mount help for 77 crossmember in 66 c10 using 94 clamshell engine mounts
If you use the frame brackets from the '77 C10, you will need a spacer on top of the frame about 1" tall. The C20 and C30 frame brackets fit the early frames much better. Some guys still use a 1/4" spacer on top of the frame.
Thanks, Captain fab. Would any welding be needed for the 1 inch spacer?
No you do not have to weld it. Just sandwich it between the engine mount bracket and the top flange of the frame.
i did a very similar thing your asking about. 1964 c10 with a 1977 c10 crossmember. 1999 vortec 350 with clamshell mounts. I mounted the 77 c10 perches, and as captain said, they are too tall, by about 1 inch. I didnt like the look of a spacer, so i cut each perch in half, removed the necessary amount of material, and tig welded it back together. fits like a glove now
Thank you guys for the help, it is a head scratcher.
