1952 Chevrolet 3100 on s10 frame with LSX- build thread
So I figured I might as well make a build thread. I started out with a 1984 single cab long bed S10, a front clip, a cab from a 52, a short box from a 49 and a 1999 4.8 litre and a 4l60e. I paid 300 for the s10 delivered, 800for the clip and cab and title, and 300 for the 49 box. The truck will be matte bright white with gloss black grille, bumper, door handles... All the trim. Cab is sound deadened with fat mat. I have Dakota digital vhx gauges, vintage a/c, stern beast 20" wheels, tanks Inc fuel tank and set up, psi wiring harness... And a bunch of other nice parts for it, I designed custom hood emblems also. Pics coming!
Here is the 52 parts hat I started with . https://s3.postimg.org/rxjv1yoj7/image.jpg Here are the truck parts https://s3.postimg.org/5ktl73rv7/image.jpg 4.8 with 120,000 on it https://s4.postimg.org/pg237by8t/image.jpg |
Re: 1952 Chevrolet 3100 on s10 frame with LSX- build thread
I read everyone else's posts and changed he measurements a little because I want my truck on the ground but with no air ride... So here are some of the mounts I made
Some weld action :) https://s3.postimg.org/r218fbo6b/image.jpg https://s3.postimg.org/bhtuose1v/image.jpg I made some panels and brad rolled them for the firewall https://s3.postimg.org/rxx506rib/image.jpg Seat installed and column mocked up https://s3.postimg.org/xnddkhxoj/image.jpg |
In having a local upholster do my seat, door panels and headliner kind of similar to this
https://s3.postimg.org/o2wlh1lur/image.jpg These are the wheels I have 20x9 Stern Beast wheels. I wanted a somewhat modern resto mod type look https://s3.postimg.org/f9aadoo9v/image.jpg These are the headlights which I think will be awesome against the matte white https://s3.postimg.org/yfnhgv4rn/image.png |
Trans painted
https://postimg.org/image/btacyu3yn/ Motor painted, did the valve covers matte white. I used a 1970 gm fleet bright white and then sprayed a matte clear on top https://s3.postimg.org/ck334m6c3/image.jpg Intake cover, it rid of the vortec https://s3.postimg.org/mvffx9y1f/image.jpg Here are the logos I designed and had a friend cut them out with a cnc laser, these will be gloss black on the sides of the hood https://s4.postimg.org/qrrhtwrj1/image.jpg |
Hand made trans crossmember, it's now bolted through the side and the top
https://s4.postimg.org/958qf1ox9/image.jpg More weld action https://s4.postimg.org/c0ltlwsx9/image.jpg Frame painted with chassis saver-I'm gonna drive this thing ! https://s4.postimg.org/pjmm98twt/image.jpg |
Dash primed after I filled some holes and built a small cubby hole
https://s3.postimg.org/ub3o3rsxv/image.jpg Had to check one of the gauges out ! https://s3.postimg.org/c70nj4v9f/image.jpg After I had it mostly mocked up https://s4.postimg.org/d0ebpjrh9/image.jpg I did 3" drop lower control arms and 3" blocks in the black Most of he body work done, I hand made the front part of the floors and trans tunnel as well as shaved the hole for the fuel fill https://s4.postimg.org/khnj4rh0d/image.jpg That's all for now.. Should have my interior back in a week or so and I'll use it painted and hopefully done in a month, maybe a little longer. |
Looks like a good start to a great build..love the new hood emblems..what's your ride height? That looks mighty low..that wouldn't work where I live..haha
Thanks ! I'm going to stain the wood black also.. And do gloss black steel
strips in between the wood. I've never seen a matte white with gloss black trim 47-53... Ever. So I hope it turns out like I'm hoping :) |
At the front of the running boards it's right around 5 inches off the ground. I think it looks lower in the picture than in person.
What do the dots mean?
Sorry bout that..everytime I post and hit my back button it will double post my original..it didn't use to do that but here lately every time I post I have to go back to the home page or it will double up...so if I catch it in time I just hit edit and put dots in it cause I can't erase it..
Oh haha no problem
Yep it looks lower than 5"..I'm shooting for 5-6 in on mine..yours looks like 3 or 4..
Looking good man. I'm interested to see how your firewall came out with your custom bead rolled panels.
I will snap a pic tomorrow
That's awesome ! I like them low. The last truck I built I did air ride, and it was cool but I didn't think it rode the way I thought it should. I did a manual valve setup on it. If I did it again I would do electric valves and height sensors so it stays at ride height no matter what when you set it. I drive quite a bit. I live a hour away from friends and family so the stuff I build has to be reliable. I did the LSX because I wanted the power, reliability and gas mileage .:metal:
great work! looks amazing
Looks great, I'll hang around for more updates...Jim
Nice build!
Upholsterer sent me a picture of one of my door panels today
https://s4.postimg.org/lii1xrivx/image.jpg |
Seat finished, just have to pick it up !
https://s16.postimg.io/lj515fn51/image.jpg Doors painted bright white and matte clear coated https://s16.postimg.io/i0t191m91/image.jpg |
Looks good, Will be following this build
Thanks ! Hoping to have it on the road in a month or so
Posted via Mobile Device |
