67 Ramp Rat...
5 Attachment(s)
It was 65* here today in SC so I worked on the ramp. Got the heater boxes all cleaned out and got the fan working. Took the switch all a part cleaned the contacts with a wire brush and put some electric grease in it put it back together and walla it works even on high. I have heat and deforst now. Got the ash tray out and cleaned the ball bearings up and lubed it it slides in and out nicely now.
A month ago I put the new aluminium radiator in it so I did the over flow tank today. No more leaks are puking on the ground. I got a factory shroud coming to for $20.00 Next is brakes. Went and picked up a Booster and master cylinder late this afternoon for it. Going to get it stopping just fine now I hope. I need to get a E brake setup for it. It's impossible to load a vehicle without a e brake. Got to buy tires some time also. Got to get the seat recovered also. My buddy has a factory tilt wheel for it also and I have the old corvette steering wheel for it. $75.00 for the tilt ant bad at all + dash pad also. This is going to be a cheap build well up til I do the LS motor swap! More to come!:chevy: |
Re: 67 Ramp Rat...
That's awesome, good luck with it!
Re: 67 Ramp Rat...
Re: 67 Ramp Rat...
5 Attachment(s)
One day at a time are in today's case 2hrs @ a time. It's all I had.
Also got the master cylinder took a part and the rod out. Going to have to order a new rod for it I guess to swap it over to booster. Got the steering wheel swapped out and the horn works now. There was so much grease and dirt on the contact it wouldn't work. Cleaned it up good and have horn working. In the taking it a part though I broke one of the tabs so it's in the shop letting the glue dry hopefully it will hold up. I'll install it tomorrow and see how it does. I did end up with a nice 67 horn cap though off the old wheel. :chevy: |
Re: 67 Ramp Rat...
nice work Andy..keep after it..these ramp trucks are neat.
Re: 67 Ramp Rat...
Re: 67 Ramp Rat...
currently truck has 1/2" bolt on D ring tie downs.I did pick up a set of the recessed pan fitting style.The anchor ring folds down flush with deck..you see them in most enclosed trailers now.I bought from a local trailer sales/parts supplier.I also had some wheel chocks made for when I am hauling..Pin goes through chock for mounting.I pull pin and remove them for loading/unloading..................google search trailer D rings ,,plenty come up from different vendors.
Re: 67 Ramp Rat...
Very nice man! I like the wheel chokes for sure.:chevy:
Re: 67 Ramp Rat...
Very cool rig.
Re: 67 Ramp Rat...
The glue is holding so far on the horn cap.:chevy:
Re: 67 Ramp Rat...
try aw direct my brother uses them for tow truck chains lightbars and such .
Re: 67 Ramp Rat...
Re: 67 Ramp Rat...
Re: 67 Ramp Rat...
5 Attachment(s)
Well it wasn't 65* yesterday and today but I manged to get the brake booster installed with new push rod and to day I took the dash out and cleaned it up and swapped out the oil gauge. I also took the speedo cable out and relubed it hope it works when I get back in tomorrow if not I'll go get a new cable.
Didn't spend a lot of time on it because later I think I'll go with a digital dash. It does look a lot better though. I took the E brake handle off to while under the dash. I have to figure out how to get the darn things all hooked back up though. For now though no e brake.:chevy: |
Re: 67 Ramp Rat...
4 Attachment(s)
Mid January and it's 70* out side! I worked on the Ramp Rat some, got the dual exshaust done + got all the cab marker lights working!
Put the heater core back in the box and sealed it up good. Just waiting on the gasket kit to reinstall it in the truck. The truck sounds a lot better with the same 2 exhaust on it. The exhaust came off the 64 Impala SS when I had it all redone. :chevy: |
Re: 67 Ramp Rat...
Proper pipes is always a nice plus.
Re: 67 Ramp Rat...
I'm chomping at the bit to restore mine but I have a bigger fish on the grill ;) |
Re: 67 Ramp Rat...
I held on to it for 3-4 years thinking I may need it but never did. If I could find one cheap enough I'd just use it instead. I'm not holding my breathe though.:chevy: |
Re: 67 Ramp Rat...
Like the tail lights but I think they need a mod.. the bird has to go..
Re: 67 Ramp Rat...
3 Attachment(s)
Got the heater box back in and no leaks. Tomorrow I may try and get the rear end done. Had to do some honey do's today so didn't get to spend as much time with it as I had plan.
Took the passenger side mirror off also and took it to get a new mirror in it. :chevy: |
Re: 67 Ramp Rat...
2 Attachment(s)
Took the old seat out and replaced with a 90 model seat. Put the drivers side harness in have to make a LQ yard run to pick up some more belts. Installed the new strob light also.
Took the hump out and sealed it up good and put more screws in it. Got to get a rubber mat for it and the inside should be done.:chevy: |
Re: 67 Ramp Rat...
The light is cool, seat looka good too. And your playing in the leaves video came up on YouTube, that little deal looks fun there
Re: 67 Ramp Rat...
Re: 67 Ramp Rat...
You only go digital if you have an LS in there.
Re: 67 Ramp Rat...
That's right! My goal is a LS motor at a later date. I want to find a nice size tank to go under it also. Maybe like a motor home tank.:metal: |
