Transmission lines 4L60e to stock 71 rad cooler
Help, I have looked and read lots on this topic and the more I search the more conflicting answers come up.
Can I ask this question one more time? Looking for the fitting size and tread type form a 4L60e to stock 71 radiator transmission cooler. I will be running a hose replacement. Thanks so much! |
Re: Transmission lines 4L60e to stock 71 rad cooler
You'll want 1/4" NPS fittings at the trans.
Ok, Thank You!
Now what size is need to the stock 1971 GMC rad cooler,and hose size recommended. |
I can't help you there. I've yet to own a '67-72.
I'm sure someone will remember,
I know this has been asked many times! |
The original tube is 5/16". Regular tube nuts with a double flare on the tubing should go in both the factory trans. fitting (the "adapter" fitting that racecouger mentioned) & your radiator.
You will want to use either metal tube or braided hose with correct ends...regular rubber hose & clamps is NOT the way to go. Lorne |
So a 5/16 male inverted flare fitting is what I need?
I used these fittings with the stock 4l60e lines.
http://i1123.photobucket.com/albums/...D34269975F.jpg http://i1123.photobucket.com/albums/...F79D309122.jpg |
I've been trying to figure out the same thing! i just got my 5.3l/4l60e dropped in this past weekend. Great info uxdesigner.
Ran AN fittings and Russell flex lines neatly along the frame right into the radiator cooler.
Its important to get the correct.transmission fittings for.the 4L80. |
Daaaan67-can't send you a private message your box is full. Have a question in another thread about your dbw gas peddle bracket.
Double-check which is inlet and which is outlet on the trans, as they're not all the same. I don't know which way the 4L60E runs, but for example the TH400 and 200-4R are reversed from one another I think.
[QUOTE=cosmo2u;7934905]Daaaan67-can't send you a private message your box is full. Have a question in another thread about your dbw gas peddle bracket.[/QUOTE
Ok cleared up some. |
Guys, I'm running a Champion EC369 radiator and will be retaining that for my 5.3/4L60E swap. Can I reuse the lines from the TH350? I would prefer to go that route if possible. My second choice would be to go with AN fittings and line. I know they make the adapters for the transmission side but not sure what I need to adapt the cooler side. According to Champion, the fittings in the radiator are 1/2" 20 straight thread G 1/4".
You can use your old lines, you will just need adapters maybe at the trans..
Any ideas which adapters I would need for this?
Bringing this back to the top. I have the correct AN adaptors at the transmission (4L60e) now which AN fittings do I need to thread into my radiator? Specs of the EC369 state that the trans cooler fittings are 1/2" 20 STRAIGHT THREAD G1/4. Also which is in and out of the radiator? Top I would assume is the inlet...thanks all.
Did you ever get an answer about the radiator fittings? |
https://www.holley.com/products/plum...ts/AT991946ERL |
Do you have the part number for radiator fitting for some reason I cant read the number pitcher is blurry thank you
This one fit perfect for me.
