Center Console for buckets
I have a 67 Suburban with 04 Suburban seats in it. I'm not going to use the stock center console out of the 04 Suburban because it doesn't fit very well in the 67. Does anyone have pictures of a center console that they have used or built for their Suburban? I'm looking to mount two cup holders, arm rest, storage compartment and the radio in the center console then leave the dash all stock. I'm going to be looking for a radio block off plate as well.
Thanks, Nick |
Re: Center Console for buckets
I have the 99-02 Silverado/Tahoe/Suburban etc console in mine.
http://i27.photobucket.com/albums/c1...pspafuedvm.jpg |
Here is a Toyota Tacoma? with imp.ss seats in a 72 sub
If you use the search function you can find dozens of threads about homebuilt/made or modified consoles. Pickups will have the same basic dimensions. Good luck with your search.
I went to the junk yard and found a center console out of the rear of a Lincoln Navigator. It fits perfectly between the 2005 Tahoe bucket seats in the front.
