dennys driveshaft
I was looking at denny's driveshaft , i was wanting to get new shafts made and upgrade to a 1350 series joints and upgrade the tranny yoke and the pinion yoke as well
but can i use the slip joint style rear shaft for my 72 Fleetside with coil spring rear end?? anyone else running a Dennys drive shaft two piece |
Re: dennys driveshaft
bump
I would save the money, I have grippy tires 275/60/15 M/H 4200 stall with trans break and still running the 1310 joints I wouldn't worry unless your dead hooking .
Look at the 3/4 ton pcs, on the driveline....my longhorn does run the slip in the middle, with 1350 joints. The old longhorn is leaf springs, but if you look at the 3/4 ton coil set up....on an 8 ft box truck, it will have the slip in the middle;) the 1/2 ton trucks , had the rubber hanger in the middle, with no slip yolk....not the best deal at all. I would talk with Dennys, on your app, & see what they have to say? Longhorn
