Drag Link
Quick question.
Which way does the drag link install on 73-87? Long end at steering arm and short end at pitman arm? Or other way around? Thanks |
Re: Drag Link
Short on the pitman arm, Long on the steering arm!
Re: Drag Link
That's what I thought. Thanks!
Is that a Borgeson steering shaft? |
Re: Drag Link
Its the CPP version. You just need to make sure you get the spine counts and sizes correct. Its like $120 bucks
Collapsible steering shaft |
Re: Drag Link
depending on your vintage 73-87 parts wise . . . a jeep steering shaft is a 98% drop in for much cheeper and gets 2 u-joints and bye bye rag joint .
