Tires Size for 70 K20
I'm trying to decide what size tires to put on my 70 K20 project. I bought a set of 5 16 inch steel wheels last year and want to replace the 16.5/33/12.50s on my truck. Last year, I saw some different tires on 67-72 trucks at some truck shows. Here are the three tire sizes that I saw: 235/85/R16, 255/85/R16 and 285/75/R16. Any suggestions would be helpful as I am going to look at tires this week.
Re: Tires Size for 70 K20
agree with Joe, both of the sizes he mentioned look nice on a K20. Here are 235/85/16s on my 72 - I'd love to see a 265/75/16 on stock steel rims for side-by-side comparison. I have seen them in person and liked them (the 265s) but not side by side with the skinnies.
^^^I agree. I've got 265/75/16 on mine also.
I like tall & skinny! 235/85 or 255/85
thx sicklajoie! I forgot that's what you had. They look great. Hmmmmm.......
Anyone got a pic of a 255/85? I don't see many of those very often. |
245/75/16 works for me if you like the stock look.
Last year I replaced my 33/12.50-16.5s with 255/85-16s on 7" Ford wheels. About 1" taller than OEM 7.50-16s.
Before: http://67-72chevytrucks.com/vboard/a...1&d=1465915948 After: http://67-72chevytrucks.com/vboard/a...1&d=1465879810 |
Here is the truck that I saw with the 235/85/16s this past summer.
255/85r16 on 16x7
Steel wheels look so nice. If wouldn't have found the 16.5 tires for my mags that was my next choice.
Sicklajoie I just reread the thread on your truck (again) such a great ride. |
has anyone run 285/75/16s with stock ride height? if so, pics pls:)
285/75/16 on ford 16x7 wheels.
If you are looking for a stock look, which you didn't mention, you would want 235/85-16s. They are the closest profile to the old 7.50-16s. If you are used to looking at bigger tires you'll want either 285/75-16 for tall with some beef...about same height/couple inches less width than 33/12.50s, or if you want to go closer to stock width go with 255/85s...about same height/around an inch wider than stock. All these tires will work on stock height mounted on a 6-7" rim. 7" is better for those sizes. What width wheels did you get, stock?
I tried to find some of those 16x7 Ford wheels for my last K20 and couldn't find a set around here. Ended up getting 16X8 from Summit (wheel Vintique). I have no use for the 16X7's now but if I stumbled across a set I would snatch them up anyway, just so I wouldn't feel defeated haha.
I picked up two 8 lug rims with 245/75/R16 tires on them for $20. One will be a spare when I get new tires for the steel wheels in the future. I plan to put both of them on the rear axle and hope to get some used tires for my steel rims and get rid of all four 16.5/12.50/33s that are dry rotted. I hope to start the body work next month and will get brand new tires whenever my truck is road ready. I have some engine work to do but it is a project that is my #2 project. My other project is a vintage semi truck. Thanks for the tire size suggestions.
Joe, that looks like stock ride height - any rubbin issues or really close, etc? I may lean backwards a little narrower just in case based on Allchev's note. It will be a while before I wear out my 235s, but one wants to be prepared ;) |
My '72 K2500 had 255/85-16s on 7" Accurides with old original springs that left about 1" to the bump stops and never had them rub. I have a picture as my phone screen saver but it was in my old computer that broke
Got it Joe, thanks. I might go one size skinnier then. Sorry Heavychevy, didn't mean to hijack.
