Need help on 93 c1500 fuel pump won't turn on.
IDK the wiring diagram but I do know that it's linked to the oil pressure sender I'm order to power the relay but need help if anyone can help on what wires are powered & which one goes to the ecm & which one runs to turn on the fuel pump, thanks.
Re: Need help on 93 c1500 fuel pump won't turn on.
Welcome to the board!
Fuel pump relay wire colors 1993 C/K gasoline engine: Red (circuit 490) – ALDL connector terminal “G”(for early years) or Test lead Dark Green with white tracer (circuit465) – From PCM (computer) this controls the relay Gray (circuit 120) – to fuel pump - earlier TBI trucks had tan with white tracer Black with white tracer (circuit 450) – Ground – to engine ground G109 (by T-stat) Orange (circuit 440) – power from fusible link at firewall junction block The ECM controls the fuel pump relay. The truck has a fuel pump relay that supplies power to the fuel pump when: - Anytime the ECM receives a distributor reference pulse. (Engine running / engine cranking) - The key is turned on engine not cranking – relay applied for 2 to 20 seconds. When the engine has oil pressure a redundant circuit supplies power to the fuel pump. This circuit goes through an oil pressure sensor/sender. This circuit is independent of the fuel pump relay. |
