Leaky doors?
I have been working on door repair for the last several months. (1957 pickup). These doors/cabs are a pain to align. I finally got the drivers door decently adjusted and shutting flush.
Today I put on the door seal to make sure all was still good. Seal is "Precision" brand. Lets just say that most spots are wide enough to throw a dead cat through. Am I trying too hard to make these doors fit and seal up? Should I be looking for thicker door seals? Even with thicker door seals, I doubt the upper frame around the window would seal. These doors are too flexible up there. Can they be made to keep the water out? |
Re: Leaky doors?
Re: Leaky doors?
You are missing something, the doors aren't aligned or the rubber is on wrong. Yes there are brands that don't work well but the extreme you are at, it sounds like you have something wrong. Post some photos.
Brian |
Re: Leaky doors?
One additional thought, I know if you are using weatherstrip seals for these trucks, you can put them on backwards. In other words, they can go on backwards, with the extended rubber lip laying against the body, rather than sticking out. Good luck.
Morrie |
Re: Leaky doors?
Start by che king the integrity of the actual door frame itself. My old doors have several cracks in the tin in the window channel area plus the hinge mount area. If I grab the door at the latch end and twist it the door is flexible enough to allow a twisting movement due to the broken structure. If yours is the same then fix that first and then get the door to fit the opening and adjust the fender to fit the door. Thats just my wY of doing it. If the fender is off you can hang the doors with the hinges loose enough to move, then close the door and adjust to fit a d tighten the hinges when done. You could read up on doctor martinsr's door adjustment bible. He has it figured out. Great job Brian. Thanks for posting those "from eperience" articles that help so many of us.
Re: Leaky doors?
if the rubber seal looks good, it's probably backwards
correct direction http://i306.photobucket.com/albums/n...ps00fecc12.jpg |
Re: Leaky doors?
Thanks guys.
Brian, Ogre, I think it's backwards. :banghead: After the last adjustment, I think the door needs to go back 1/16". dsraven, Quote:
Brian, I have been reading your "basics" for many years. Thanks. http://i953.photobucket.com/albums/a...ps9ymfuegh.jpg http://i953.photobucket.com/albums/a...pso83bu882.jpg http://i953.photobucket.com/albums/a...psgmkmnwj4.jpg |
Re: Leaky doors?
Yep.. looks backwards when compaired to ogres truck,, it does look a little close at upper front corner.
Re: Leaky doors?
Yep it's backwards, on the door fit, getting it better, yeah it's possible but honestly, they were NOT very good from the factory, hints the huge rubber seal. :D
Brian |
Re: Leaky doors?
Yes, that is backwards. Don't feel bad, it's a common mistake. I did that on my last truck and it was a glue-on seal.
Re: Leaky doors?
Re: Leaky doors?
I have heard of using a banana for scale but never a dead cat. does it have to be dead so you can throw it? :lol:
Re: Leaky doors?
I turned the seal around. All the holes line up, except the ones along the bottom, had to redrill.
Fix one problem, create two more. Before putting the seal on, I had the doors working really good. Latches were smooth. Now I have to slam it to compress the seal. Do to the tension on the latch, it takes two hands to push the button to get it to release. From the belt line down sticks out more than 1/4". The seal won't compress enough to get the door flush. But, the upper frame fits nice. Snug and flush. http://i953.photobucket.com/albums/a...ps9zqstna2.jpg http://i953.photobucket.com/albums/a...psbvgsshia.jpg http://i953.photobucket.com/albums/a...psdy3ajwof.jpg |
Re: Leaky doors?
my buddy had the same problem with his 54 and the seal he got from a well known supplier. tried everything. then tried softseal and it was like night and day. fits well first time. his doors fit well,then he installed the first set of seals and his doors looked just like yours, sticking out too far. took that seal off and got some softseal and they fit like they should now.
usually I like to install the seals after the paint,if that is your plan, to paint it. not saying thats the right way, just the way I do it. your way may be better in that you fit EVERYTHING first. worth a try i would say.good luck. |
