How much spline engagement do I need?
I'm working on mating a 6L90 to a np205. I have the short 29 spline transfer case input, and the shortest 4wd 6L90 output shaft. After I get done cutting everything to length, I'm probably going to have about 1.5" to 1.75" of engagement of the transmission into the transfer case. I haven't found anything out there whether this will be enough.
The truck won't see a lot of abuse and it won't be a high hp/tq build or anything, so I'm thinking it will be alright. What do you guys think? |
Re: How much spline engagement do I need?
offroad design has a kit for that combo .
and when I checked a 203 input and a 205 input there was basicly 2" of spline on them . so I try and fill it all up the best possible. I would say if you get 1.75 tho you should be fine . . . but I am no expert in this combo area . |
i dont understand what parts you have. you should be using a coupler if using the 29 spline dodge np205.
Do you have the aftermarket female 29 spline input? |
At the bare minimum you want to be engaged the diameter of the spline. So if the diameter is 1.5 that is your minimum
Sorry for the confusion. The 4wd 6L90 has a 29 spline output shaft, so I believe when you order this kit AdvanceAdapters you get a female 29 spline dodge shaft for the 205.
I am going to try and keep as much splined together as possible, but I do need some clearance. I think it will be very close to 1.75". |
Call off-road design. I believe their spacer is shorter giving the most engagement possible.
A shorter spacer/adapter makes the problem worse. The shaft is only splined about half way down, and there is only 2 7/8" of splines. Where everything is mounted right now, the transfer case is about 1" from mounting to the transmission.
Shortening the shaft by 1 7/8" means that there isn't room for the 2" of transfer case input shaft, so this will need to shortened as well. This would be a lot more clear had I taken a few pictures, but I was annoyed that there was so much of a gap, so I took some measurements and called it a day. I can post pictures later this week. |
Ok, I gotta ask. What in the heck is a 6L90? Is it the same as an Allison? Are they put in the newer trucks?
The 6L90 is a revised version of the 6L80. It is said to have been designed to replace the 4L80 (in form and function), and uses clutch-to-clutch shifting and does away with bands completely. The 80 and 90 share about half their parts. They have the same gear ratios:
1st - 4.027 2nd - 2.364 3rd - 1.532 4th - 1.152 5th - 0.852 6th - 0.667 R - 3.064 Production started around 2005, and are being pretty much replaced by the 8L90. Evidently, you can only get a 6L90 in a 1500 series new truck. All the rest have 8L90's. You can find them in Camaro's, Corvette's, vans, and trucks in both 4wd and 2wd versions mostly between 2006-2016. These are not Allison transmissions. They require a CAN bus to operate, so they came behind gen IV ls engine. The 6L80 uses a 32 spline output that is the same spline as a 4L80. The 6L90 received a 29 spline for 4wd applications and a 36 spline for 2wd applications. |
I did read your other thread with Clinebarger on it. Very impressive build. I wouldn't ever even think of doing more than removing the pan to change the fluid. Very cool upgrade! |
