Leaf spring interchangeability
I have a 72 gmc jimmy trying to find 1/2 ton leaf springs shackles and leaf spring frame mounts. Are the later model Silverado 1500 4x4 shortness interchangeable
Re: Leaf spring interchangeability
Not positive but I think later models are different. What are you dealing with, if you could post photo's. My 72 Blazer 2 leaf springs were nearly flat, spring shackles in front are integrated with radiator support.
I am keeping my fronts to lower the truck back down in my old age. They are nearly flat even when removed.
3 Attachment(s)
These are my suspension pieces that I want to replace with stock hardware
How do I flip these pictures on my iPhone they are right side up and when I uploaded them they were right side up
You have got some monster plates for that lift kit, is it all removable?
How soon do you need the stuff I have a blazer I will be cutting apart but need to keep it moveable right now.
What's your plans for the stuff your taking off I can bolt it on to keep it moveable?
Sounds like 1 Rippen 6 has got what you need, I have complete 72 4x4 drive train from 2wd conversion, I would rather sell the whole lot together.
The thing is it's my daily driver so I can't take the parts off and ship them to u sorry wish I could but I do desperately need some stock stuff it looks freaking ridiculous with 30" tires on it lol but whenever u get a chance to take ur stock stuff off I would be interested in buying it il be listing my lift kit stuff on here as soon as it comes off when I get stock stuff to put on
If someone wants to swap my stuff for stock suspension and can ship there stuff first they can have it as I have no use for this lift kit
I would def give my stuff to u if u could ship ur stuff first I will pay to ship my stuff to u in the same box or boxes
U can have the leaf springs to if u would swap those also I know the fronts are 2.5 " lift with a extra thick helper spring rear has same lift but no add a leaf 5 leaf pack
By the way these parts are all bolt on the front of front leaf spring mount has body mount integrated into it
1rippen6 can u post some suspension pics of ur blazer
This is a pic of my front suspension if u want to swap I will give u the high steer setup cause I don't think I can use it with stock suspension
B-50, Shackle flip, lift springs and cross over steering for stock suspension? Very very tempting considering i plan to lift mine... how do the shocks look?
Haven't taken the shocks off but I did get a hold of some stock frame mounts and just ordered some tuff country ez ride springs so this stuff will be for sale on here soon
I would like to change the steering back to normal drag link but I don't have the spot on my drivers side steering knuckle to mount curved steering arm diff numbers are c40386 next to pumpkin
On steering knuckle is 370056 anybody Id the front diff for me?
