removal of generator battery control module
2005 5.3 harness trying to remove the Generator battery control module as I do not think it is needed in my 1949 Chevy truck . Any help will be appreciated .
Re: removal of generator battery control module
Bypass the wiring, have your tuner flash the ECM with a 2004 O/S. You won't lose anything you'd need in your swap, and it deletes all the GBCM functions.
Thanks very much for your input will give this a try .
You will have to wire it like an '04 also. There aretwo wires that go to the PCM. You may also need an older alternator, the one with the flat plug. When I did my '06 with the round plug, even with it wired and tuned for an '04 it still defaulted to 13.8v.
Thanks , i am side tracked on truck for the moment but will follow your advice , thanks again.
2 Attachment(s)
I probably would if you have it. Seems to me it's a better way of controlling the alternator, and isn't really that much more wiring. It's a couple of power wires and some grounds, then the rest just go between the GBCM and the PCM so there's nothing really to be done. You will have to splice the serial data wire, but that's about it. Here's a schematic in case you need it. The schematic is two pages, even though it looks like one, so that's why it looks funny. I cant put them all on one page and still be able to read them.
Now I have more to think about , thanks for all the input that has been shared .
Any one actually using gbcm on their trucks and are there any issues ?
That,s what i thought also , need more input , thanks
Thanks, any special wiring or is the information provided in previous posts the way to go ? Thanks for all the input.
Need help I am trying to reinstall gbcm on 2005 5.3 the part number for the plug is a Delphi pa6-gb20-gf10 can not get this number to come up anywhere, also need the part number of the pins that go to plug. Can any help me find them. thanks for your help.
that string you listed on the connector, is not the part no. It is the recycling code for the plastic...FYI.
The Delphi p/n would be something like 6-8 digits just numbers. do you have a pic of the connector maybe I could help ? |
Thanks , for all the help looks like help desk is giving me 13545282 or new number 13545282 as plug number after sent photos to them. Customer service at Mouser .
I will have to admit that I am a slow mover on my truck will pick up the pace soon .
Eficonnection.com is a great source of LS connectors and they offer most of them as pigtails.
I hooked my GBCM up per the instructions/wiring diagrams. Nothing changed, still defaulting to 13.8 V. Does something have to be updated in the tune? Is there a way to troubleshoot the GBCM? TIA
Did you hook up the Blue wire , engine on signal , some say to store it as its not needed , but, does this control gbcm. The link to the acdelco information is no longer available that i can find. Just thinking out loud.
