68 chassis ????
Did these come with power steering? I just bought one with a power steering gear on it and a 350 turbo. Not sure what transfer case it has. I didn't get a good look at it and I won't see it again till next weekend. If i go with this thing I have some 3/4 ton next gen axles I can upgrade too.
Re: 68 chassis ????
Power steering i have no idea,The t case could be a rockwell or a np205 or maybe a np203 if i remember right.
Re: 68 chassis ????
Power steering was available in 67 but it was a power assist ram type setup, usually prone to leaks and pretty rare. Ive only seen 1 in person. There were no automatic trans in 67-68 4x4s, only 4 speeds so if you have a TH350 its been added and the T case will probably be 203 205 or 208. Ive never came across a Rockwell mated to an auto trans.
Re: 68 chassis ????
I think you are right about the transmission and transfer. It's a 350 and a 203. The power steering is factory with the dimples on the frame. I actually went and got it today and talked to my body man about a plan. Thanks for the info. The 350 and 203 will work for me for what I am going to use it for. I think my daughter is going to let me have her 72 Blazer for a parts truck.
