Fuel filler neck hose diameter
Does any one know the factory fuel filler neck diameter and where's a good place to purchase the rubber fuel hose that matches it? TIA
Re: Fuel filler neck hose diameter
I just got some fuel filler hose from Rock Auto. I have some left over, but I think the bigger size for the square body tank. I got a 90 degree elbow for our size neck and then a reducer bushing, then the bigger straight hose.
https://www.rockauto.com/en/tools/ho...r+hose,1001643 |
I found this place in a search several years ago. I dropped the tank in my '89 to replace the fuel pump and the hose was unusable because it became rock-hard and impossible to work with.
Try http://www.fillernecksupply.com/ I was able to get a section of new hose that worked for me. |
I did the one on my 67 it was 1 3/8" hose ans was seven inches long. Had to order a foot to get it from a local parts house. It took a day to get here. I am assuming you mean this hose?
https://www.fillernecksupply.com/car...5-7171635ad219 |
Unless you are in a hurry, i have some new Gates 1 3/8 gas filler hose (GAT 24702). I can easily send you a long enough piece in a small USPS box.... no charge.
any chance a guy with a '65 could get 4 inches of that 1 3/8th?
mine is toast and i would gladly pay postage. |
Happy to. pm me your address and exact length you want cut and I'll send it off to you on Monday...
Pm sent , I thank you.
