Bit by LMC again
I installed a heavy duty headlight harness and light from LMC 'bout 6 months ago. Worked great till a month ago. Pushed dimmer button for brights and got nothing. By the time I got home brights were working again. Since I had bright light indicator, I didn't think it was dimmer switch. Happened again tonight - shot it to relay.
Anyone know if there is a none Chinese relay that will fit LMC plug? Thanks I will also post in electrical but thought this forum is more active - going out of town this weekend. |
Re: Bit by LMC again
I have the same upgrade kit and wondered the same thing, how long will the relays last? want to find a couple of spares myself...anyone???
LMC has replacement relays on their site - if you want more of the same.
Found it was relay by swapping them. I went to Summit and got a couple of spst relays. Had to solder and shrink rap new connectors. |
We used Bosch relays in squad cars and fire trucks. They lasted a long time
