Hummer Seats
2 Attachment(s)
I've been eyeing a set of SS leather seats when I stumbled across these from a Hummer H3. Thoughts?
Re: Hummer Seats
I like the looks of the SS seats better.
Re: Hummer Seats
I like the integrated seatbealts on the hummer seats myself...one less thing to deal with. How tore up is the base of the SS seat on the left?
Re: Hummer Seats
I would use the ss seats...my.02...and without the headrests..
Re: Hummer Seats
Not sure yet. Waiting on additional pics.
Re: Hummer Seats
tall seats with a headrest will take up half the back window and look out of place in a classic
ogre says no to both :D |
Re: Hummer Seats
SS seats minus the headrests. Those others just don't cut it even if they are free.
Personally the SS ones would look better if they didn't have the SS on them but some guys might thing that logo is worth some bragging rights. Plain they would look a bit custom, with the logo they looked pulled off the wrecking yard self and stuck in but still look 100 times better than the Hummer seats when going into an AD or tf truck. |
Re: Hummer Seats
shoot fire...I thought that SS would add 10-15 hp..
Re: Hummer Seats
if you are able, slip one in the truck before you get too wired up on either. the taller the seat the further forward it will have to lean because it will hit the back wall of the cab. I have seen some where the driver almost has to lean forward when the seat is back far enough to accommodate leg length. not a very comfy seating position. also, check the foam in the seat. it may be packed out from use especially on the outboard side where occupants slide across to get in/out of the vehicle.
personally I like the idea of integrated seat belts and an arm rest. just my thoughts though. |
Re: Hummer Seats
I'm trying to meet up with the seller of the SS seats to do some measuring. I also did a search here and saw where certain Nissan seats work well. |
Re: Hummer Seats
2 Attachment(s)
i had a set of tall back seat with headrests and yes, the high back moves the seat forward
removed the headrest and chopped 6'' out of the seat back to move it back as far as i could this option involves custom upholstery i also raised the seat 2'' over stock bench seat height and have an electric seat on my side i'm the shortest male (of six) in my family at 6'4'' :D |
Re: Hummer Seats
Looking at this ebay add the middle seat out of the H2 might be a better choice than the front seats. Only issue for some is the 60/40 split with the narrow part being the passenger seat that is the 40 part. Without the headrests the seat back should be about the same height as a stock seat. Flip down arm rest lets you have the armrest or flip it up out of site and for a third person to ride in the truck. You have to scroll the pictures. http://www.ebay.com/itm/Complete-Fro...4AAOSw0hlZMHQu
For the prices they want for an H2 seat on Ebay you can buy a custom seat all done up and ready to bolt in. |
Re: Hummer Seats
2 Attachment(s)
Re: Hummer Seats
I snagged a complete set (front & rear) from a 04 Avalanche, seller didn't want to separate the set. Did a quick test fitting using the rear seat and I'm not so sure it will work. For me, it sits a tad bit too high. Also with the cup holder folded down, it get's me in the hip. I'm going to play around with it this weekend to see if I can make it better. If not, I'll just use the buckets. Pics to come.
