New! Pro Series Static Drop Kits
Our Pro Series air ride kits have been popular with our customers, so figured why not do the same for static drop kits. We put together static kits that use quality components from different manufacturers, to offer you a well rounded suspension setup.
63-72 Static Drop Kits 73-87 Static Drop Kits Example of the Pro2 63-72 C10 Kit 4"/5" Drop Kit The Pro3 63-72 C10 Static Drop Kit has the basics needed to install a quality static drop on your truck. We use most Street Edge components (Made in the USA), and pair that with quality shocks. Of course, we include the adjustable panhard bar and rear shock relocaters so you know the job will be done right. Kit Includes: 1 - Street Edge 3" Drop Spindles 1 - Street Edge 1" Front Drop Springs 1 - Street Edge 5" Rear Drop Springs 1 - Dead End Garage Adjustable Panhard Bar 1 - Dead End Garage C-Notch 1 - Dead End Garage Rear Shock Relocaters 4 - RideTech HQ Shocks 1 - BellTech Front Sway Bar http://www.azproperformance.com/imag...ro3-sdk-01.jpg |
Re: New! Pro Series Static Drop Kits
Very nice kit. Do you guys have anything for the 47-54 trucks? Thanks, Chris
Unfortunately no, since most guys will completely change the suspension anyhow. Plus no one that I know of makes drop leafs, being they are leaf in front as well. I could be wrong, but don't recall anything out there.
what does a set of 2.5" lowering spindles cost through you guys?
truck is a 72 c10 swb |
For the 2.5", you can do the McGaughys and runs $240.
